UPGRADING TURBINE HOUSING ? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-21-2012, 06:49 PM Thread Starter
bha4424's Avatar
HEY GUYS I HAVE A STOCK TURBO AND WAS THINKING ABOUT CHANGING IT TO A INDUSTRIAL INJECTION .84 TURBINE HOUSING OR 1.00 TURBINE HOUSING
IS IT WORTH THE MONEY ?
AND WHAT WOULD I GAIN ON A 97 7.3 TUNED AND STRAIGHT PIPED WITH 1.5 A INJECTORS ? ANY MPG FROM IT ?
bha4424 is offline
post #2 of 15 Old 12-21-2012, 07:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
caps lock is a terrible tool, but you will increase your spool time and have less lag by decreasing your exhaust housing, but when going with larger injectors and a smaller exhaust housing you increase your egt's by a lot, and that is bad, you should also look into an intercooler if this is the route you wish to go, otherwise stick to either injectors or the smaller housing, not both, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 15 Old 12-21-2012, 07:40 PM Thread Starter
bha4424's Avatar
so i should just get a hole turbo thats bigger
? i would love a intercooler but dam thats expensive
bha4424 is offline
post #4 of 15 Old 12-21-2012, 11:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
lol, i have less then $200 in my IC set up, and you shouldnt get a bigger turbo kause lag will set in hard kause you dont have enough fuel to spin it, all i am saying is if you go smaller housing sticks wont be needed, if you did both then you have to watch your EGT's more often kause more fuel=more boost=higher egt's and over spinning the turbo, so do the housing now, when you get injectors go back to a stock housing if you do stage 1's or 1.5's if you go stage 2 then get a D66 turbo, and so on and so forth, but you should look into an intercooler if you decide to tow much and want that kinda fuel and boost going
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 15 Old 12-22-2012, 07:46 AM Thread Starter
bha4424's Avatar
ok thanks i know you can use a 6.0 intercooler but can you use the piping off of a later model 7.3 also what else can i do to lower egt's it is a work truck that is why i did not do stage 2 injectors i have a intake and 3" dp cat and muffler are deleted also this may be a stupid question but would a d66 turbo help lower the egt's when towing even though it may have some lag
bha4424 is offline
post #6 of 15 Old 12-22-2012, 08:19 AM
Full A-Team Member
Fordman247365's Avatar
What injectors do you have? if they are stock and you put a D66 turbo on, your EGT would go up due to the lack of fuel to lite the turbo, thus lugging the truck causing higher EGT
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #7 of 15 Old 12-22-2012, 09:00 AM Thread Starter
bha4424's Avatar
unlimited diesel stage 1.5 a
bha4424 is offline
post #8 of 15 Old 12-22-2012, 09:03 AM
Full A-Team Member
Do not put a smaller housing on the turbo, a D66 should work really well with them
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #9 of 15 Old 12-22-2012, 09:21 AM Thread Starter
bha4424's Avatar
thanks what about a 6.0 intercooler and tubing off of a late 7.3
bha4424 is offline
post #10 of 15 Old 12-22-2012, 03:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
6.0 will work, but the pipes need to be custom, i have a 6.0, i think shane has the same cooler too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
