6 pos chip switch mount - Ford Powerstroke Diesel Forum
Old 12-15-2012, 09:05 PM
I put in my TS 6 pos chip and aFe intake today.
The switch for the chip doesn't come with any kind of mount for attaching it to the dash.
I'd like to hear what has worked for some of you.
Old 12-15-2012, 09:47 PM
Question
I'm in with you buddy ???? Where have you put your switch????
Old 12-15-2012, 11:37 PM
Just drill a whole the size of the threaded part of the switch (test it by sliding the nut from the switch on the drill bit to find the right size) then it can put any where you want as long as the cord reaches. I mounted mine under my steering wheel by just drilling a whole into the plastic under it.
Old 12-15-2012, 11:59 PM
Thumbs up
Thanks Buddy!!! But if you check out my intro thread.. the rock Crawling buggy is something I have built!!!! If ya want to see more Pictures let me know!!!! It has a LS-1 Vette motor in it!!!
Old 12-16-2012, 04:52 AM
Diesel Freak
Mine is beside the wait to start light looks almost factory
Old 12-16-2012, 06:11 AM
I'm less concerned about where to mount it then how to mount it.
I don't see how the switch comes apart. I've tried pulling on the knob but I don't think it comes off. Do I need to pull harder? Even if the knob comes off, what do I use to actually mount/attach it to where ever I put my hole in the dash.
Old 12-16-2012, 06:20 AM
there should be a very small allen head set screw on the knob itself, back it off and the knob slips off, then there is a nut on the threaded part. drill hole, slip through, tighten nut and replace knob and retighten set screw, done!
Old 12-16-2012, 07:59 AM
Great! Will check it out. Thanks.
Old 12-16-2012, 05:45 PM
Got it mounted thanks.
Now I just need those injectors to come in and get that DP on.
I think I'll own it for 7 more year.
I wonder if the transmission will hold up.
Old 12-16-2012, 06:04 PM
Full A-Team Member
That my friend depends on the driver
