Cat/Muffler delete question. Emissions? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-15-2012, 05:12 PM Thread Starter
Currently I live where no emissions testing is required. We may move, however, and I'm a little concerned with removing the cat and muffler if it has to pass wherever we move.
Will deleting them affect my chance of passing emissions and what is the advantage anyway?
Thanks for the patience with a noob.
Rancho5 is offline
post #2 of 4 Old 12-15-2012, 05:46 PM
erics diesel's Avatar
your best bet if you may move to where they do testing is to get the "test"pipes that will alow you to put your cat and muffler back in for testing just make sure you use band clamps and not the regular ones that crimp the pipe down. the benefit of removing them is they are restrictive for the turbo. it will work more efficient with no restrictions to get rid of the exhaust faster and lower your egt's.
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 4 Old 12-16-2012, 10:57 AM
Blazin8556's Avatar
I thought diesels didn't get emissions testing. Guess it depends on where you live. Memphis plugs into the obd port to make sure there is no check engine light. I took an international bob truck through and they didn't hook up to it, they just made sure everything works. (of course it does not have a obd port, but they asked about it)
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #4 of 4 Old 12-16-2012, 11:56 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
Parts of Cali do have emissions testing but it is no more then a snap test. Go on a breezy day and you are hard pressed to fail. No visual testing as there is no standard for what is supposed to be on the truck (and only '98 and newer) and no sound laws as the laws are written for and stated within either for vehicals with less than 6000GWR or more then 15000GWR.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
