best down pipe/ installation tips; 1996 250 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-09-2012, 04:59 PM Thread Starter
oldblue'96stroke's Avatar
I'm sure this question has already been answered, but im looking to swap out my stock flat down pipe for a 3" pipe.
however I'm leaving my stock cat in it and some aftermarket dps wont fit onto the factory cat. (MBRP)
my questions are:
Which is the best dp to go with? (since some modification will be needed to get the down pipe onto my factory cat)
also what modifications have y'all encountered swapping down pipes?
any help is appreciated,
thanks!
oldblue'96stroke is offline
post #2 of 12 Old 12-09-2012, 07:32 PM
kramarj's Avatar
If you use the search you will find a bunch of threads about it.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
post #3 of 12 Old 12-09-2012, 08:56 PM
atvrider93's Avatar
Quoted: 8 Post(s)
I don't know for the stock cat. But I think the Diamond eye one will bolt right up. basically just the cut the old one out, cut the pinch weld on the firewall a bit, bend the firewall up a little and slip the new one in.
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #4 of 12 Old 12-09-2012, 10:59 PM
cntryboy17's Avatar
Why not delete the cat and let your truck breathe and live a happy life?
Sent from my SAMSUNG-SGH-I847 using AutoGuide.Com Free App
FB: Kyle Durflinger
E99 F350 CCSB 4x4, Auto, All stock for now..., straight piped
1990 f-250 7.3idi 4x4 5 speed
Originally Posted by oldtimer550 View Post
Chevrolet = French word for non-hetero buttsecks.
Originally Posted by 1tonpower View Post
the wait for the coverage articles in DP is like waiting for a girl to put out for the first time....
cntryboy17 is offline
post #5 of 12 Old 12-10-2012, 04:21 AM
I just posted this in another thread but when i was installing mine i wish i had this info so i'll just post again.
When you decide to upgrade the factory pancake downpipe, find a scissor jack and use it to push your firewall in a little bit. This will save you a ton of time and frustration.
I spent quite some time trying to fit my diamond eye DP in there and it was not going to fit, but as soon as i used the scissor jack and moved the firewall it fit just fine.
Buck Futter is offline
post #6 of 12 Old 12-10-2012, 09:49 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
now thats a great idea, i used an air hammer and cut the pinch weld out with it fit fine after that, i used a diamond eye and it went rite on to my factory cat, good luck with yours bud
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 12 Old 12-19-2012, 07:46 AM
when you guys do add an aftermarket down pipe, do you remove all of the insulation from the bottom/firewall area of the cab?
1996 F250 XL 7.3 PSD ZF5 Red SCLB ...79k miles and show room stock
wishIhada5.0 is offline
post #8 of 12 Old 12-19-2012, 02:04 PM
superduty4x4's Avatar
I wish I had thought of that...
I bought a porta power and used the duckbill to push the firewall back.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 12 Old 12-27-2012, 06:46 PM
leojr's Avatar
Quoted: 4 Post(s)
I am really fretting about this. Am collecting pictures of this so I can focus on the exact area needing clearancing and how to do it the least destructively as possible.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #10 of 12 Old 12-27-2012, 06:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
i bought a $26 air hammer at home depot, came with 4 bits, cut the weld in 2 spots and used the handle from my floor jack to bend it down by prying on the motor (bent my floor jack handle btw), you will need to cut the cobra head off the stocker to pull the rest down, took me a while but i used short blades, long blades would have made a lot quicker work
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
