egt sensor install questions and intake questions for a rookie - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-07-2012, 05:56 PM Thread Starter
Hello i am new here and have just bought a 1996 f350.. i bought a banks turbo downpipe and it has a spot for the egt sensor.. what wld be the acceptable range for the sensor if i installed it there? The truck is stock and i wanted to install the down pipe and get a baseline before i did other modifications to it. Alot of ppl suggest putting the sensor in the manifold. I am a little gunshy about drilling it. And has anyone tried installing the ford severe duty airfilter kit from a 99 psd onto an older one?
ford182002 is offline
post #2 of 7 Old 12-07-2012, 07:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
dont know much about the severe duty filter, but as far as the down pipe goes i had one in the DP and is obviously 2-300 degrees off from the manifold, you actually wanna know whats going in the turbo not going out of it bro, so manifold, i drilled the drivers side one and then tapped it, took all of a couple hours and get a good tap and die set to do this with, i didnt worry much about the shavings since they were falling as i drilled up, and my turbo is just as happy and healthy none the less, i have an afe all metal intake and i love it over my fram knock off of the 6637 mod, good luck and welcome to the org
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 12-09-2012, 01:10 PM Thread Starter
Ok cool thank you wld you happen to know acceptable temps for it? How high of egt is bad?
post #4 of 7 Old 12-09-2012, 01:32 PM
erics diesel's Avatar
egt in the manifold shouldn't exede 1200 degrees for very long
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #5 of 7 Old 12-09-2012, 01:45 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
1250* is about as high as you wanna get it, anything more than that it needs to be short bursts like a few seconds max, but i cruise at about 600-800* but i am also intercooled, good luck
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 7 Old 12-30-2012, 10:34 AM
r_jacksondiesel's Avatar
Location: Sunshine Coast or Baja California...Depends on the temperatiure
I tried searching on here but couldn't find it.... Is there a good write up on how to install and EGT sensor and gauges showing where to drill the manifold and keep the shavings out of the turbo?
r_jacksondiesel is offline
post #7 of 7 Old 12-30-2012, 10:37 AM
Full A-Team Member
Fordman247365's Avatar
Bottom of the driver side manifold on the flat spot. If you run the sensor post turbo, 900* is about as high as you want to go
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
