3'' downpipe removal?
OK guys lets see if you can help me out here im working on my buddy's 97 OBS 7.3 i put the new 3'' down-pipe in and well i didn't clearance the firewall just enough and well in the cab feels like your sitting in a vibrator lol its bad. well its a 2 peice and its clamped so no taking it apart. it looks like i can get it out but would have to remove the passenger exhaust up pipe.... anyone had to take one of the new 3'' down-pipes out before please chime in. i have thought about a tiny body lift he siad no ive tried sticking a pry bar in there just no room any ideas????
Mines a two piece and clamped. Anytime I need to pull it I just heat the outer one a little. Do you have anything that breathes fire?
It can be an absolute pain if you don't use a band clamp. I got the one out of our work truck some how by twisting it perfectly and it came out the bottom. Once I got it out it was still a pain to get it apart. Next time you should use a band clamp, no squishing that way, or that's the way I would do it anyway. Using heat is a good idea, never thought about that, just as long as it is just the expanded part.
ok well after posting i went back out and messed with it a little more the clamp i tighted it and it never crunched the pipe..cheap POS they send with it. but heres my other thing ive got a little propane tourch i can get up in there to heat it up a bit. theres no way the things will come out in one piece at least not on this truck lol. but ill try heating it up and twisting and pulling on it. i just dont wanna bend up the flange on the turbo. its wierd the clamp is all the way tight and still moves around i tried loosening the down pipe at the turbo and using a bar to move the pipe away from the firewall and tightin it but as soon as you pull the bar the pipe slides right back. so somehow im gonnah ave to figure out how to get it out. on my own truck it has the 3'' downpipe and rubs and in the cab you hear the vibration but if you pull up on a curb to twist the fram a bit it gets so quiet in the cab like the truck isnt running
I just put exhaust on a truck and it was fine at first, but it must had moved a little and started doing just what you are describing, we ended up having to really push the pinch weld way in and the flange on the turbo had to be like perfect. It wasn't the same as the other couple kits I put in, this one was odd though, seems like the flange was a tad bit smaller than the others, all three were Diamond Eye kits too. Make sure the downpipe isn't rubbing on the up pipe either.
Yeah I can see the up pipe and there's about 1/2" of room there just the firewall that's touching. So tomarrow If its not pouring rain I'm going to try to mess with it more
I've also noticed that every trucks is a little different on how the pipes fit
hearing stuff like this makes me want to do a DP back and call it a day....
