best turbo for a 7.3 - Page 6 - Ford Powerstroke Diesel Forum
post #51 of 69 Old 11-20-2012, 07:30 PM Thread Starter
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
only good shot i really have of it
89 F350 with a 97 E350 7.3 in it
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #52 of 69 Old 11-20-2012, 07:32 PM Thread Starter
Quoted: 11 Post(s)
Originally Posted by ol_Blue97 View Post
Trubo, boost leaks, post turbo exhaust leaks, bad injectors.... could be anything. Just need to get it on a scanner and look at engine parameters
had taken some stuff off, that wheel inside the turbo spins fine,doesn't hesitate, it still has the stock ford downpipe?? leading from the turbo then down to a magnaflow exhaust/muffler
-Jeremy
Got A Few Rides...
post #53 of 69 Old 11-20-2012, 07:38 PM
rocksmearer's Avatar
Thats a sweet setup. I meant of the engine in the truck
rocksmearer is offline
post #54 of 69 Old 11-20-2012, 07:44 PM Thread Starter
Quoted: 11 Post(s)
OH, sorry here, i can get better ones tommorow, these were more about the turbo and hose setup and such
ID:	45979   Click image for larger version
-Jeremy
Got A Few Rides...
post #55 of 69 Old 11-20-2012, 07:58 PM
I get that. as soon as you said out of a van it peaked my interest. Wow, that is straight out of a van.I run 160/80's and a d-66 with Tyrant tunes and am more than happy with it if that helps. Your set up is so much different that I wouldn't even know where to begin as the WHOLE van setup is swapped over.
post #56 of 69 Old 11-20-2012, 07:59 PM Thread Starter
Quoted: 11 Post(s)
im looking into a ts 6 pos chip here soon, focusing on making my turbo louder and getting a better exhaust and such
also anyone know where to get some hoses/ pipeing or what ever to mount to the 6637?? unless ole blue has it?
-Jeremy
Got A Few Rides...
post #57 of 69 Old 11-21-2012, 07:58 AM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
Looks to me like you are going to have a problem using the 6637 because of where your oil fill and power steering reservoir are located
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #58 of 69 Old 11-21-2012, 08:14 AM Thread Starter
Quoted: 11 Post(s)
it will be mounted on the pass side, above the tire
-Jeremy
Got A Few Rides...
post #59 of 69 Old 11-21-2012, 08:24 AM
Quoted: 77 Post(s)
With that silencer in there it probably would be best to start new tubing from the turbo but if you use metal intake tubing just make sure that it can't touch any open electrical connections like the ones on your glow plug relay
Jack
322000 miles
post #60 of 69 Old 11-21-2012, 08:40 AM Thread Starter
Quoted: 11 Post(s)
gonna remove that silencer and everything, anyone know what this vent is? has a hose under it that leads into the motor
ID:	46026   Click image for larger version
-Jeremy
Got A Few Rides...
