DIY - IDM mod (Injector Mod) - How to w/ lots of pics
So start off by saying I know there is already a write up by richdawg (IDM Mod 140 volt - Ford Truck Enthusiasts Forums) thats good and I used it doing mine but I figure more info can never hurt and I added more pics.
OVERVIEW: COST - 1$ resistor, 6$ sealant, 15$ soldering gun, 5$ solder DIFFICULTY - If you can turn a wrench and use a soldering gun EASY TIME - start to finish took maybe an hour (not including dry time) Heres where to get the resistors : http://www.digikey.com/product-detai...KXTR-ND/594453 SUMMARY: This is an awesome mod and was super easy to do and really lets you take advantage of the factory system to its fullest by upping the factory injector voltage from 100 volts to 140 volts which opens the injectors faster and holds em open longer giving you more fuel. So using this mod with intake and exhaust would be recommended. MAKE SURE YOU HAVE A PYROMETER (Exhaust gas temp guage) and do not MELT YOUR ENGINE DOWN. Lets begin: Mine was a 100v IDM (see last 3 numbers) ![]() So mine required the 75 resistor ![]() On with the good stuff. -start by unhooking the battery negative cables on both batteries -next locate the IDM module in the drivers fender under the hood -3 8mm bolts to unbolt and 1 10mm bolt holds the connector on. ![]() ![]() -Next up I used a heat gun to warm the sealent all around to loosen it up ![]() -Then a flathead screw driver and gently pry'd a corner up ![]() -Then used 2 flatheads and twist one then slide the other farther and repeat. ![]() -Once the covers up, look around for any damage, corrosion, exploded capacitors ![]() -Then use a razorblade to clean all the old sealant out ![]() -Here is what i used to get the job done ![]() -Here is the chip to remove ![]() -Just use the soldering gun and a toothpick and heat up the solder and put a little pressure with the toothpick and it pops right off. ![]() -Here is the comparison to the new resistor both on a dime ![]() -Bend the ends of the resistor over and solder it on. Everyone has their own preference here. ![]() ![]() -Heres the RTV i used to seal it up ![]() -Cut the tip down to around the size of the lip and go to town ![]() ![]() -Put the cap back on and let it sit till dry, I'd say at least 8-12 hours -Reinstall in reverse order ![]()
good write up where did u get the resistor from?
updated it in the first post.
DigiKey Corporation - Electronic Components Distributor heres the one i used for the 100v IDM's SFR16S0007502FR500 Vishay BC Components | PPC75.0KXTR-ND | DigiKey |
thanks man i just ordered some
I've got baby swamp injectors and tuned chip, would I notice a difference if I did this? Thanks
U will notice a little more throttle responce. This is not a mod that adds HP, it is just one that allows u to get full potential out of all your other mods. I would recommend everyone to do it, stock or modded truck. I got mine sitting on the counter ready to do something with.
I may send mine to swamps to get the high frequency high voltage mod done. |
matt the weatherman would disagree he's seen dyno's that say they add 30 hp
who??
how do u know what resistor to use? could it change depending on the idm? would it matter which direction u put the resistor in?
