E fuel 95 f350 question.. - Ford Powerstroke Diesel Forum
Old 11-03-2012, 04:01 PM
hey guys just 20 minutes ago I finished my efuel set up on my truck, used a superduty pump 4770 bases etc. but my question is the aeromotive 13109 regulator, it says its factory set at 43psi and is adjustable from 35-70psi, but when i fired my truck up it was at 81 psi, has anyone ever had this problem? i have a fluid filled 0-100psi gauge mounted in the port on the regulator as well. thanks in advance for any help you guys can lend..
Old 11-04-2012, 04:40 AM
Diesel Freak
You can try adjusting the regulator or make sure your return lines are unrestricted ie. kinks or sharp turns
Old 11-04-2012, 08:33 PM
Ok I checked that, didn't see any kinks the turns aren't real sharp but ill try another route with them.. The 80 psi worries me.. Thanks for the response.
