help with performance
hello all. i want to get my truck to have some more ponies but idk where to go next. i have a ts performance 6 position chip and a fuel system tha should be able to handle 250cc injectors. but i am kinda clueless when it comes to injectors. i dont know what stage to get or what all the differnt specs mean like "AA" for example. any help or ideas on more power would be greatly appreciated. thankyou
What has been done to the truck already? If you are still using the stock air box and exhaust system I would start there. If you want bigger sticks you will have to upgrade the hpop to supply enough oil to the injectors and get your chip reburned for them.
i have a 4 inch diamond eye dual exhaust with 5 inch tips. straight pipe no cat or muffler and a k&n filter
Imho ditch the k&n and do the 6637 filter. What is your goal for the truck (fun, towing, pull truck etc) will help determine what injectors to go with
i pull with it at local fairs. im planning on rebuilding motor within the next year or so. it has 302000 on it. so i do truck pulls but it is my daily driver also lol. and what is the 6637 is that a napa filter or what?
it is a filter that you can get at napa or several places online that filters better and flows more air than a k&n does
i now u said the fuel system can handle 250cc but how do u know that? what kind of pump? who's system? DIY? who's chip or just a cannned tuned ts 6position?
the fuel system is a single pump from bully dog and is advertised as being able to run 250 cc injectors without changing the hpop and the chip is from ts performance and is custom tuned. stock,high idle, 50, 75, 100, 150
Custom tunned by who?..... a lot of tunners out there that have different pros and cons? Do u have a link? I cannot find any fuel system made by bully dog? Or is it a BD Performance or Air Dog?
Just trying to grasp what u have on the truck so we can send u in the right direction without causing damage to your truck or engine! Only other thing i can think of is that fuel system is for a cummins and was modified for the powerstroke. Reason being is that pump can handle 250cc injectors without a upgraded hpFUELp. Since they have low pressure and high pressure pumps. Any 7.3 with with 250cc injectors will require an upgraded HPOP espically in a 94.5-97 truck. |
use the search button,
then get your wallet our for some real mods |
