Another E fuel question
Im considering doin the swap on my 95. I wouldnt mind the swap. but im on a very limited budget. I may be able to get an aftermarket Raptor fuel pump from a friend off of his cummins. He is using it with his stage 2 injectors and says its just not enough fuel and is goin a different route soo i may be able to get it cheap. I would like to keep the fuel bowl and fpr temporarily. Just want to mount a small inline filter pre pump, and the pump on the frame. Seen online you can get a "banjo block" that allows you to re-use the lines from the heads to the factory pump. This would be temporary until I could afford all the new lines, fittings, regulators, filters, all that good stuff. Anybody have any suggestions?
you just want to get rid of the mechanical fuel pump and start the process of the swap and not need to purchase everything?
I mean...I dont see any reason why you can put electric fuel to the fuel bowl/fpr....it would work as far as im concerned, the mechanical pump does the same thing, but if you have the pump and the pre-filter, we are talking 180$ of expense out of the way. all thats left is misc lines(<50$) a post filter ( 30$ ) and a fuel pressure regulator(I paid 140 for mine, but you might be able to get them cheaper). either way we are talking less then 250$ and you could do the hole e-fuel, thats a pretty good deal. buy the pump, save it till you get the cash, or you can try to install it into the fuel bowl/fpr, but if the mechanical one is working fine then I see no reason. |
