1997 Ford 12v First Gen Cummins Swap
Hey guys im new to the forum, nice to be here. So im starting a big project with my 97 Ford F250HD. I am buying a 89 dodge cummins and putting everything in my truck. I was looking for so help from you guys and see what i can gather. I have plenty of questions so please help me out.
Welcome to the org.... have you done things like this b4 or is this something new to you?
Ive never swapped but i used to have a 96 psd and did a bunch of after aftermarket and general maintence to her
That's awfully ****ing stupid... why would you want to lose the horsepower, torque, aftermarket, high rpm power of the v8 powerstroke?
Actually man its not stupid because i had a 351 with an auto tranny. Ask before you talk im here hoping to get pprofessional diesel advise thanks
Hmm.. interesting. What trans are you using? That might be interesting. I personally would have just bought a truck that came w/ the diesel instead of trying to rig everything, but good luck
Well for now im putting the getrag 5 speed in it that is coming with the 89 cummins but its only two wheel drive tranny so eventually find a four wheel drive tranny. The reason im using my 250 for a swap instead of buying a diesel is because i have a lot of work done to the axels and everything underneath. I did the solid axel swap on the front end with a F350 axel. I have 5.13 gears, detroit locker in the rear and welded spiders in the front with lockout hubs. Put disk brakes on the rear instead of the drum breaks. I have F350 rear leaf springs up front to allow more flex to her for crawling and trailin. But when i get the cummins motor in she will be my chick magnet and ill find another mud truck!
Sounds like a good start so far... lots of hard work into it.
I also have 375 inch military runflats off a humvee on her with 24 bolt beadlock rims with rock rings and rock sliders under the rocker panels
37 inch that is
