Propane Injection - Ford Powerstroke Diesel Forum
View Poll Results: Propane Injection Thoughts
Have propane injection Off The Shelf system 1 16.67%
Have propane injection, homemade version 0 0%
Want propane injection, "smart" closed loop system 1 16.67%
Want propane injection, "dumb" open loop system 0 0%
Dont want propane, I think its really a proPAIN 4 66.67%
Voters: 6. You may not vote on this poll
Old 08-16-2012, 11:28 PM
Propane Injection
How many people are running propane injection?
"...Fogging or fumigation type dual-fuel systems require little modification to existing engines. The mixture of gaseous-fuel with the intake air charge is introduced into each cylinder of the engine during the intake stroke. During the compression stroke of the piston, the pressure and temperature of the mixture are increased in the conventional manner. Near the end of the compression stroke, a smaller than normal quantity of diesel fuel from the engine's existing diesel fuel injection system is injected into the cylinder. The diesel ignites due to compression and in turn ignites the mixture of gaseous-fuel and intake air, which in turn, accelerates the flame front of the Diesel Fuel, enhancing the combustion process. As will be appreciated, such fumigation systems may be retrofit onto existing diesel engines with little or no modification of the existing engine. Furthermore, engines using such fumigation systems may typically be operated in a dual-fuel mode or in a strictly diesel mode (e.g., when gaseous-fuel is not available). "
-http://www.americandieselsystems.com/diesel-reduction-technology.php
Old 08-20-2012, 07:13 AM
If you think it's a pain, explain why. Just because you heard it was is NOT a sufficient reason.
Old 08-20-2012, 08:25 AM
Diesel Freak
As long as you under a load like towing up a hill it is ok to do just don't fog at lower gears as it may take off and ping off the rev limiter which will probably spin main bearings bend push rods break off rocker arms list goes on and on....
Old 08-20-2012, 11:04 AM
1. You don't fumigate with propane at idle or out of gear so you shouldn't ever run into that issue of hitting the redline
2. How much propane are you talking about at low gears???
You can run into issues just like propane with methanol. As methanol atomizes, it becomes a low cetane fuel (auto-ignition very unpredictable). Because of this fact, you can encounter severe knock due to rapid burning of the vaporized alcohol and thus, combustion quenching caused by its high latent heat of vaporization and subsequent charge cooling. As everyone here knows, diesel needs charge heat/temperatures to combust effectively.
Old 08-20-2012, 11:08 AM
Diesel Freak
I was just giving him a warning Ive seen first hand when a guy did a burn out he used propane durning it and detonated his block it was a bad sight and sound he was on dry pavement and had 46" Superswampers on the truck too they ate a hole right through the asphault.
Old 08-20-2012, 03:12 PM
Sounds like a failed attempt at controlling the propane system...
I guess he learned the hard way, you cant just put a hose into the intake with a tank attached....
Old 08-20-2012, 04:29 PM
De-rail in 3... 2... 1...
But you can run into the stack with an spark plug.
Old 08-20-2012, 08:02 PM
Diesel Freak
I think it was a bully dog system
Old 08-20-2012, 09:22 PM
Then his system was broken because you cant build any good boost pressure unless under a large load, and the bully dog system doesnt inject propane until 7psi
Old 10-08-2012, 08:26 PM
pro propane
just wanted to say i like your perspective on the propane their are an enourmous amount of honest people out here that have been misguided into a diy propane kit that has left them sitting or has been misused and cost them some money but noone ever wants to discuss why does anyone out their have a story of their rig where propane did damage and want to explain why i would be very curious i am building a two stage propane kit for my rig now so some first hand failed attempts would be good reading.
