Anyone ever install energy suspension leaf bushings? - Ford Powerstroke Diesel Forum
Old 08-14-2012, 11:33 AM
I bought the rear leaf poly kit. There are 2 sizes(2 big ones and 4 smaller)but the lower rear shackle looks even smaller. Before I take the springs out anyone done or used this kit before? Thanks! BTW, heres a pic how its turning out.
Old 08-14-2012, 02:55 PM
Just did it yesterday. It wasn't too bad. One of the center steel bushings required reaming, but the others fit quite well. I did rear spring hangers, shackles, and bushings at the same time.
Old 08-14-2012, 02:58 PM
I have done them on the truck using a torch (small propane or mapp)
the pressed bushings will squirt out when hot enough
otherwise a press is good but holding a spring horizontal will need a helper
Old 08-15-2012, 05:11 AM
Did you guys use the energy suspension kit oem style bushings?
Old 08-15-2012, 07:35 AM
not sure what you call it ? but the one I did was replacing a pressed in style for two half shells and a sleeve
Old 08-15-2012, 07:40 AM
OK, its seems either Daystar or energy suspension makes the kit. Thanks! I'll work on taking pics so maybe it can help someone in the future.
Old 08-22-2012, 07:08 AM
Figures I have a problem. The shackle arn't OEM and look to be made by Dorman. Their is no metal sleeve on the bushing with these and its smaller than the 35mm needed for the poly bushings. Anyone run into this issue? I really wanted to intall all the poly bushings! The others in the leafs fit perfect........
