Is a egt gauge a must have?
Well I have a 95 obs with DIY intake, stock straight pipe, and tuner. I'll be towing often but mostly a daily driver. Will I need an egt gauge or other gauges?
Sent from my Autoguide iPad app |
Of course it is.. ESPECIALLY when towing, ESPECIALLY with a tuner! Unless you like molten metal underhood.
YES, YES, YES!!!!!!
Buy a good quality gauge like issapro or auto meter and dill and tap the probe in the drivers side manifold not after the turbo........ |
Shouldn't be... they should drill out. If there is, suck them up with vacuum
No you should be fine. first off you will be drilling upside down. second you need to drill a little then clean the hole out, drill, clean, drill, clean till you break through. Iv heard of guys loading the bit with grease just befor they break through , but i just used a shop vac.....
Remember to use a tapered reamer befor u use the pipe tap .
(i think its an 1/8-27npt threads). you wont get a good seal unless you do. |
I didn't bother cleaning it, just drilled tapped and screwed it in, your tuner probably says that the use of an egt gauge is strongly suggested, I know edge products say that, and I agree you NEED GAUGES, if you have an auto get egt, trans, and boost minimum
