Early 99 Intake Question - Ford Powerstroke Diesel Forum
Old 07-05-2012, 04:16 PM
I have finally gotten around to getting an intercooler put on my truck and have a question about the intake spyder. There are four holes on the spyder that need sealed. The two threaded holes are easy and finished. Where I am stuck is with the two ports that look like they were for boost pressure since they are not threaded and simple had a barb fitting in them. Those of you that have used this intake on your truck what did you seal these holes with?
The help is greatly appreciated!
Old 08-23-2012, 05:47 PM
im looking and getting one too, they got a bard fittting? put a lil piece of hose with a bolt in the other end and clamp it. if thats the case its ugly but would prolly work
Old 08-23-2012, 06:14 PM
Real Men Love Jesus! <><
The barb fittings are for a map sensor tube, and the other is a vacume line. You could do away with the vacume line, but keep the map port and install a barb fitting and run it to you boost guage or whatever....
Old 08-23-2012, 07:49 PM
^^^If he still has the stock fuel canister it will have to be removed. Both hose barbs will pull out with a pair of pliers. I just drove in tapered steel pins with loctite on them but you can just tap them for a pipe plug or set screw, just needs to go in flush with the outside of the housing since it is so close to the fuel canister.
Old 08-24-2012, 03:29 AM
oh, i didnt realize on an OBS that the fuel bowl was so close. they have the bowl up further or the turbo back further on the SD's
Old 08-28-2012, 06:31 PM
I just had all the holes on mine welded up.
The fuel bowl on the SD is on top of the hpop and the OBS sits behind the hpop
