Ugh another problem - Ford Powerstroke Diesel Forum
Old 06-29-2012, 08:55 AM
Ugh another problem
So long story short , my wheel fell off on the way to another state, its been in the shop while I was on vacation. If you remember I was having a problem with my truck idling as I coast. Well I pick up the truck, that problem has gone away. but now it seems to have alot less power. Is this another sign of a hpop going out? Its fine in stock mode , but when I kick the 6 pos switch into extreme it's not much quicker then stock.
I still haven't gotten it on a code reader I'm going to work on that next week
Old 06-29-2012, 04:04 PM
De-rail in 3... 2... 1...
Have you cleaned your fuel bowl and FPR screen? Maybe she's just hungry?
Old 07-02-2012, 07:20 AM
I replaced the fuel filter problem solved
Old 07-02-2012, 07:34 AM
Cool. If it's been a very short time since the last fuel filter swap then keep an eye on it as you may have gotten a bad fill up at a station that buys dirty fuel or doesn't change it's filler filters very often. If the filter is still good after the next couple fill ups then you aught to be good. If it's still dirty then you need to run as dry as you dare on the tanks to get that **** out. Happy motoring.
