Air to water intercooler - Ford Powerstroke Diesel Forum
Old 06-27-2012, 11:35 AM
Has anybody ever thought of or put an air to water system on their obs? I'm thinking about doin it as I have everything that I removed from the mustang.
Old 06-27-2012, 11:42 AM
This sounds interesting, been thinking about it, but hell I just got the concept on air to air,
Old 06-27-2012, 12:06 PM
depending on use it would be sweet. uses are pulling, drag racing, dyno queen.
If it is a street driver, I would just do an air to air and call it a day.
Old 06-27-2012, 02:07 PM
What's the benefit of air to.water tho?, would that translate to even better egt's, the 6.7 has an air to water set up correct?
Old 06-27-2012, 02:16 PM
Air to water has a lot better heat transfer but to run it on the street, you would need to install a seperate radiator to cool the water for the ic which is just a big pita for a street driven truck if it is making south of 500 hp IMO.
Plus, I don't think I would want to mount an air to water ic in the front of my truck because it would block all the incoming air that needs to go through the radiator. In that case, you would need tp find an alternate mounting location for that (I have no idea in an OSB) then install the ic radiator up front. Then run plumbing and pumps and maybe a reservoir, which would total up to quite a bit more time and money for what I think isnt reasonable gains.
Old 06-27-2012, 02:18 PM
I'm not sure of it has an air to water or not. Haven't had the chance to nose around under the hood of one yet.
Oh, yes it would lower egt's more but for how long before the water is heated and not cooling as well I don't have an answer for that.
Old 06-27-2012, 02:37 PM
Yes the 6.7 has an air to water unit, and it would be easier to do than an air to air unit, just an idea I've been throwing around.
Old 06-29-2012, 01:26 AM
Most use air to water intercooolers in situations where space is at a minimum. The radiator for an a-w is less than 1/2 the size of an equally matched air to air intercooler.
Sent from my Autoguide iPhone app.
Old 06-29-2012, 03:57 AM
Ive been looking into intercooling my e350. And in that application where room is non existant for a front mount and piping an air to water is the better choice.
Check out frozenboost.com they have some cheap air to water kits.
Old 06-29-2012, 05:34 AM
I just went on there My brain is turning.....
What if I were to buy one of the air to water coolers and plumbed the water into my coolent system (witch stays around 180*-200*), instead of mounting a whole new cooling radiator.
