Has anybody ever thought of or put an air to water system on their obs? I'm thinking about doin it as I have everything that I removed from the mustang.
Bump to a old thread. Has anyone ever tried using cooling device ( co2, nitrous, etc) to cool the water immediately before going into the air to water cooler, instead of just cooling the outside of the cooler? Kind of like an oil cooler, but using it to cool the water charge instead? of course this system would still utilize a heat exchanger.
Although it would be very frowned upon by environmental agencies I’ve seen liquid Freon sprayed thru atomizing nozzles aimed at the OEM intercooled which worked EXTREMELY well. I don’t recall the temperature drop, but it was significant. CO2 and nitrous would not last very long, plus you have the hassle of high pressure cylenders to contend with.
water to air intercoolers are great and ton of kits and places are around . the biggest problem is heat soak issues and other then that it works great most supercars and bmw and so on run them
yup i was playing around looking into few things and came across this , i agree most 7.3 have really no use for this it is an intresting topic short of the heat soak problems and running the extra tubing
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
