Easy to swap exhaust housings? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-26-2012, 05:15 PM Thread Starter
I'm gonna guess it's just a matter of pulling bolts and swapping housings? Can I do this w/ the turbo on the motor, or is this gonna suck *** and make me pull the turbo?
85_305 is offline
post #2 of 9 Old 06-26-2012, 09:52 PM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
You are best off to just pull the turbo. The worst to get at bolts hold the housing to the exhaust collector so once they are pulled it's a piece of cake.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 9 Old 06-27-2012, 05:12 AM Thread Starter
Bahhh. I've pulled so many turbos it disgusts me to think about! Thanks for the input
85_305 is offline
post #4 of 9 Old 06-27-2012, 03:35 PM
95redrifle's Avatar
Quoted: 3 Post(s)
Your gonna have to pull it
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #5 of 9 Old 06-27-2012, 03:58 PM Thread Starter
I was looking at it an hr ago, and it looks like I can do it while in-truck?? Should I pull just the turbo or does that entire flange on the block come out with it?
85_305 is offline
post #6 of 9 Old 06-27-2012, 04:21 PM
95redrifle's Avatar
Quoted: 3 Post(s)
The bolts on the back the hold the housing to the center section would be a night mare to get to. Like you said youve pulled tons of turbos so you should be able to get it out in 20 mins. or less and save yourself a big head ache
tony
1997 F250 4.10's
south bend clutch
post #7 of 9 Old 06-27-2012, 04:27 PM Thread Starter
So should I pull that manifold that bolts to the block off w/ the turbo or just unbolt the turbo?
85_305 is offline
post #8 of 9 Old 06-27-2012, 04:33 PM
Quoted: 77 Post(s)
You have to pull the pedestal.
Jack
322000 miles
post #9 of 9 Old 06-27-2012, 04:33 PM Thread Starter
Ok thanks guys
85_305 is offline
