TS 6 position problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-21-2012, 05:43 PM Thread Starter
Was driving up the driveway with my TS 6 position switch on, and accidentaly turned it to anti-theft mode. It killed the engine; I turned it back to a regular tube, but it wouldn't start. It will turn over but will not fire. Took the chip out and tried...still nothing. Seems to not be getting fuel. Check engine light is on now and cannot communicate with my code reader. Any suggestions?
tmccarthy is offline
post #2 of 7 Old 06-21-2012, 06:12 PM
What year truck is it? I know this may seem dumb but keep the chip off and disconnect batteries and ground the positive battery cable on the right side for 30 second to clear the codes and reset the system. Then reconnect the batteries without chip in and see if she will fire. If she does then install the chip as normal.
Make sure both batteries get disconnected because if not there will be lots of sparks.
dunnc87 is offline
post #3 of 7 Old 06-21-2012, 06:18 PM Thread Starter
1996. Yeah I tried that. Everytime I turn the key on the check engine light stays on. Cannot pull codes w my programmer (not installed) because it won't communicate.
Sent from my DROID RAZR using AutoGuide.Com Free App
post #4 of 7 Old 06-21-2012, 06:22 PM
Is your wts light coming on?
dunnc87 is offline
post #5 of 7 Old 06-21-2012, 06:25 PM Thread Starter
Yes for the normal duration.
post #6 of 7 Old 06-21-2012, 06:26 PM Thread Starter
It is definitely not feeding fuel. No smoke from the exhaust at all. Full tank too.
post #7 of 7 Old 06-21-2012, 07:14 PM
mkeith54's Avatar
Check the engine compartment fuses.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
