HPOP or E-Fuel First?? - Ford Powerstroke Diesel Forum
Old 06-19-2012, 09:32 PM
I cant believe i'm even asking this after JUST getting new injectors (baby swamps 150cc) and exhaust (5 inch straight) but you gotta keep plannin for the future! Anyway, what should I start stashing away for first, Electronic fuel or a new HPOP (adrenaline from Dieselsite)? I'm leaning HPOP but look to you guys, 174K on my truck
Old 06-19-2012, 09:45 PM
low fuel pressure can kill your nice new injectors, low oil pressure wont
Old 06-19-2012, 10:08 PM
mmm...good to know-what is the easiest way to check my fuel pressure? I feel incredibly ignorant asking this but hey- gotta take your lumps and learn right?
Old 06-20-2012, 02:58 AM
There's a schrader just off the fpr, if you remove that you have 1/4npt. Rig up a fluid filled pressure gauge with some fuel line and do some runs.
Sent from my DROID BIONIC against my will
Old 06-20-2012, 12:18 PM
Delivers Pizzas For Fun!
yes i would do e-fuel first... then when you regroup with costs go with HPOP, most of the guys here go with a t500 from terminator, flows the same as adrenaline, or close to it, but cheeper
Old 06-20-2012, 12:32 PM
but go ahead and check your fuel pressure once you install those injectors. if its holding fine you may not need the efuel yet
Old 06-20-2012, 08:15 PM
great stuff to know! i will certainly start saving/gathering parts for e-fuel, thanks ya'll!
Old 06-21-2012, 05:44 AM
the baconator
i also think it will be easier to install a HPOP after e fuel. less stuff in the valley
Old 06-21-2012, 11:41 AM
E-fuel and regulated return FIRST. Not only will it make the HPOP install a ton easier, but it will also help the performance of the engine and make the injectors run a ton better when they have a constant 65 PSI.
I could tell a difference in how my engine ran with stock injectors and the e-fuel.
Old 06-21-2012, 04:03 PM
De-rail in 3... 2... 1...
Another vote for e-fuel.
