Intercooler spyder?
Anybody seen these before, just wondering if they might work on our trucks?
PUSHER Intake Manifold Kit for 1999.5-2003 Ford Powerstroke 7.3L Diesel V8 Turbo | eBay |
Unless it has some sort of baffle inside of it it won't feed the right bank equally. If it does have a baffle then there is already a restriction in the system.
99.5 + use a different turbo outlet and plenum inlet size than the OBS
how can you tell the difference on a stock one from early to late 99?
don't understand what you are asking
Early 99 spyder didn't have the intake heater on the passenger side where the late 99+ had the heater there. Shape is a little different as well.
would this be an early one?
Early 99 fits your turbo, late 99-03 won't fit your turbo, that kit you need to swap in the late 99-03 plenims, pedistol, turbo, drivers side up pipe, and do an e fuel conversion kause your bowl won't fit either
nice well thanks for the help, also who makes just the pipes for the IC setup?
