Overboost code with Stage 1s - Ford Powerstroke Diesel Forum
Old 06-10-2012, 06:35 PM
Anyone getting boost sensor high codes? I believe it was a PO238. Only happens in 140hp tune. As far as I know the truck only has stage 1 injectors, no turbo housings or anything. Usually can get the CEL to come on near or above 35psi of boost.
Old 06-10-2012, 06:38 PM
Umm, well duh. 35PSI will throw an overboost unless you have a boost fooler.
Old 06-10-2012, 06:39 PM
Hey thanks, I didn't know this.
Old 06-10-2012, 06:40 PM
I'm surprised your tuner didn't mention this to you when you had him tune for the S1s.
Old 06-11-2012, 08:29 AM
I talked to PHP they didn't mention it, I see they have it listed on the website, however when ordering I didn't see a spot to "opt" out of a certain DTC.
Not a big deal, I just wasn't aware the OBS trucks did this.
Old 06-11-2012, 09:30 AM
I didn't think the OBS had over boost code.... Perhaps I'm wrong?
And if so then does the truck start to de-fuel on the top end when the code hits?
Old 06-11-2012, 10:38 AM
You can tell it looses power, It's only in the biggest tune which I rarely use, so it's not a huge deal.
Old 06-11-2012, 12:08 PM
It doesn't de-fuel, it slows the input from the IPR (IIRC), also takes at least two consecutive overboosts to set a code
Old 06-11-2012, 02:33 PM
Post Ninja!
Grab a cheap air pressure regulator and gauge installed into the "gauge" port. Plug the "out" port. Hook it to a air pressure source with a known pressure higher then 50PSI. Set the cheap regulator to 23PSI. Install on the MAF feed hose that is between passenger intake manifold and MAF port on the firewall with barbed fittings and hose clamps. Now your PCM will never see the full boost and continue to fuel as normal. Start truck and hold on!
