Garrett gtp38r in 95
I have a 95 f250 powerstroke, my stock turbo is bad and i'm wanting to know what if any modifications I would have to make to fit a Garrett gtp38r. Right now I have hypermax stage 1 injectors a ts 6 position with BTS tuning and a bts valve body. 3inch downpipe then 4 inch then 5 inch before the axle. I'm making over 35psi of boost
Do you have a 99 1/2+ motor to pull parts from? It would probably be better to just invest in a T4 mount kit. Otherwise your looking at up-pipes, spyder, intake plenums, intercooler or bypass tube, driver side exhaust manifold and possibly a down pipe. If you are planning on sticking with stage 1's, just get a d66.
what he said^^^
Ya d66 all the way.. forget a gtp38r.
I plan on doing this upgrade to my 96, but i have the intercooler already installed, also have the up pipes, and collector, just need the turbo, and pedestal, goona make a spyder... why do you need the drivers side manifold??
I also plan on getting propane injection. Is the t3/t4 adapter all that I need to run the gtp38r and is it only for the up pipes
there has been debate on whether the OBS manifold works and seals properly. some say yes some say no
A d66 flow more air than 38R... For your setup a stocker will work fine, but a d66 will hold hybrids with the right tuning.
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone... |
D66 isn't for Hybrids unless defueled...get a modded H2e if your going big..
hypermax's stage 1's are larger than other stage 1's..so ask them nozzle size and cc's..then deside on a turbo. |
| Tags |
| stage 1, turbo |
