6.0 intercooler for 7.3 - Ford Powerstroke Diesel Forum
Old 05-24-2012, 04:43 PM
I found an intercooler from an 05 6.0, and I'm looking to put it on my 95 7.3. It has the tubing from the 6.0 still. What am I going to need to make this work?
Sent from my DROID2 using AutoGuide.Com Free App
Old 05-24-2012, 06:01 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
6.0 IC will work great, 6.0 tubes wont work.
You will need either an E-99 intake spider along with custom pipes (7.3 hot and cold pipes can work when modded) or a custom after market IC pipe system. Those arent cheap, but are bolt on. If you have a welder and the ability you could fab your own pipes.
Its not a bolt in mod unless you go with an aftermarket kit...
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
Old 05-25-2012, 10:45 PM
even those need the core support cut tho, nothing is bolt in but the 6.0 ic is only thing you can use
Old 05-26-2012, 03:19 AM
Hillbilly Deluxe
What makes you say that?? I have seen plenty 7.3 IC's in obs trucks.
Old 05-26-2012, 12:33 PM
the baconator
even the aftermarket kits need to cut the core supports so they are not truly a bolt in is what kris is saying
Old 05-27-2012, 04:51 AM
Hillbilly Deluxe
Ohhh got it...
Old 05-27-2012, 08:23 AM
So is there a kit available for all the plumbing if I pick up a 6.0 intercooler. I can get a cooler pretty cheap from a local salvage yard.
Old 05-27-2012, 08:30 AM
the baconator
not that i know of. you can either by the banks stuff new i would guess it would be pricey, you can find it used (that's what i did), or you can use an E99 spyder and fab your own pipes get custom made, pipes, or rework the E99 pipes to fit
