Just Ordered a TS 6position! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2012, 06:51 PM Thread Starter
Ostrowski's Avatar
I just ordered a TS 6 position chip from xpd. I hope I can get it to the house and installed by the end of the weekend. I drive a lot for work and fuel prices are starting to kill me. I search a lot of OBS threads and I should know better by now but I went ahead and ordered the chip before ordering gauges. I know, I know.
I guess Im looking for someone to tell me that I should be alright running the 50hp setting until I at least get a pyro gauge.?? I drive like a grandpa most of the time as I don't want to thrash on the ol girl. Also, from what I've read the 75hp to 100hp settings are the best for MPG's. Unless your a hot rod. My goal is better Economy and some extra sack isn't going to be bad either.
Ostrowski is offline
post #2 of 4 Old 05-03-2012, 07:17 PM
virgin stroker's Avatar
Stay on the 75. you will be fine. even when i hot rod on the 75 setting i am safe in the temp range.
Old fat guy with stock truck.(not for long)
I DO NOT DO PICTURES.
I am an equal opprotunity offender. If i offend you then be prepared to kiss my ***
95 cclbdw 2wd
6.0 fuel pump and fuel bowl delete ( have all parts need time)done
6.0 intercooler ( have all parts need time)
4.7 zenner mod
IDM 75k mod
Ts 6 position chip
just acquired a long block( wide open performance is on speed dial)
800hp here i come (in 5 years or so)
virgin stroker is offline
post #3 of 4 Old 05-04-2012, 07:24 AM
OL' OutLaw's Avatar
you can't hurt that thing with just a chip.....all you get is about 50 hp over stock, unless you change injectors, as the 97's and older trucks have very small injectors.....the only place you might come close to doing any damage is towing on a hot day and running full throttle up a long hill...I wouldn't recommend towing without a pyro...and they are very easy to install...slide underneath and drill a hole right where you can GET the drill into the exhaust manifold boss and thereyago...
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #4 of 4 Old 05-06-2012, 09:25 AM Thread Starter
Ostrowski's Avatar
Okay. Thanks for the feedback.
