Chip problems
Hey guys its me once again this time I have a issue with my chip so I recently bought a php Phoenix chip with custom tunes and when I first got it it was set up for stage 2 injectors because it was my plan to get some but I changed my mind and decided to let my tranny live a while longer and during this time the truck ran fine a little lethargic but it ran and I recently got it reburned for stock injectors but when I got it back and I got it installed I turned the key on and there was a buzzing sound coming from the pcm and my wait to start light never went off I called bill about this issue and he said take it to a computer repair shop and have them soder a 10000th of an inch on the pcm connection and if that doesn't work send him the chip and he'd sense a new chip I was wondering if the connection points might be worn because its had 3 chips in it so I'm wondering if maybe the points are betting worn let me know what you guys think thank you and God bless
Sent from my SGH-T989 using AutoGuide.Com Free App |
first... have you tried removing the chip and tring to start it?
sounds like a bad chip to me... my buddy's truck just did that with his superchip, had to have a new scanner sent to him, and a special scanner to return the truck to stock |
Ya it fires right up without the chip
So it's either a bad chip or I'm guessing a faulty or dirty blade where your chip plugs in. Did you try cleaning them with a scotch bright pad?
Ya I cleaned the blade Hella good with the scotch bright should I clean the connection on the chip side too? & and I'm taking the pcm in today to get the blade soder to see if that works
Ya clean those too, worth a shot!?
Ok ill try that
Ya get those pins retinned as Bill said. He's probably thinking theyre getting a bit worn.
Let us know how it works after the retinning! Hope that fixes ya up!
No its the chip-_-
