why does my damn e40d rarely downshift?
It seems that my truck is very stubborn to downshift sometimes. Last night there 5 people in my truck and I was trying to merge on the highway, and since it didn't downshift it took like a whole minute to reach 60mph!
My buddies truck is somewhat doing the same thing, when it gets into a hard pull it wont downshift so the truck starts to shutter instead of going
Mine doesnrt shutter, its just got zero power because the rpms are so low
maybe the skinny pedal is screwing up? someone correct me if i am wrong but the kickdown position is controled by pedal position? (being as it's pretty much fly by wire - no cables)
does u're speedo bounce at all? maybe speed sensor screwing around too?
Yes my speedo bounces around a bit.. Figured its from my lift and tires.
I found out the problem (kinda). Third gear shifts MUCH too early sometimes, and I mean super early, and the only way to kick down is putting it into 2nd gear. |
yup, if u're speedo is jumping then i would look into replacing the speed sensor ontop of the rearend. that could be why it's shifting early into 3rd (thinking that it's going faster than it really is) hope u find the issue
Did you correct your speedo for the larger tires?
No I didn't not correct my speedo for the larger tires. I thought a tuner could do that, but they can't, I heard ts has a speedo corrector or something?
I thought its as simple as swapping a sensor in the tranny or someything, but I'm open to ideas. |
You have to recalibrate the psom when you change tire size or gearing. A chip will not recalibrate but it can change shifting points. It can be done at a dealer or do a search for speedometer recalibration. I thought I had it bookmarked but don't and have to wade through a lot threads to find the right one.
Edit: found this http://www.thedieselstop.com/forums/...on-how-155177/ Last edited by 1Dieselman; 04-28-2012 at 05:59 PM. |
