Easiest and least expensive Electric Fuel Conversion - Ford Powerstroke Diesel Forum
post #1 of 31 Old 04-20-2012, 07:47 AM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
There seems to be many different ways to go about converting to electric fuel. I like the idea of staying with the stock filter and going to an electric fuel pump and regulator loacted in the stock position. Are there good insructions or maybe a reasonably priced kit that would make the conversion to electric fuel as painless as possible?
It would look a lot like this be be MUCH less complicated to install!
http://powerstrokenation.com/forums/...ad.php?t=68965
http://powerstrokenation.com/forums/...ad.php?t=27531
I am original owner of 97 Extended Cab 4x4 with 86,000 miles, Unlimited Diesel 175/30 Stage 1.5 Injectors, ATS Intercooler, Tony Wildman 6 Position Chip, 4" Turbo Back Diamond Eye Exhaust, Stealth SPR1 HPOP, Wicked Wheel 2, Hypermax Combo Boost/EGT Gauge, DIY Intake, FPR Mod, CCV Mod, IDM Mod, 203 degree T Stat, Stainless Steel High Pressure Crossover Line, Fitch Fuel Catalyst, 40,000 lb. Trucool Max Transmission Cooler. Next up a Bean's D-66, electric fuel, torque converter and a valve body.
Frostbite is offline
post #2 of 31 Old 04-20-2012, 12:33 PM
Patrick Feeley's Avatar
Quoted: 10 Post(s)
Since the factory OBS fuel systems have a two stage mechanical pump with the filter bowl on the low pressure side, you can't use the factory filter in a high pressure electric system (it can't handle 60psi of pressure). Cheers!
Patrick Feeley is offline
post #3 of 31 Old 04-20-2012, 12:57 PM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
I had no idea! Wow!
Thanks for the info.
Does anyone offer a complete electric fuel kit for OBS trucks?
post #4 of 31 Old 04-20-2012, 03:03 PM
alvapowerchoke's Avatar
Beans or Dieselsite but there are plenty of good DIY writeups in the forums. thats what i did.
alvapowerchoke is offline
post #5 of 31 Old 04-20-2012, 03:27 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Expect to pay the price with those kits. You can put on together for a whole lot less...
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #6 of 31 Old 04-20-2012, 04:23 PM
reeseracing23's Avatar
i think i've got 700 into mine with the innovative diesel regulator set up. not real impressed with their setup, but it seems to work
95 ext cab lb, mbrp 4 in exh, e-fuel regulated retun, tymar, ts6, full force stage 1's, 120v idm,ccv mod, stealth pump
reeseracing23 is offline
post #7 of 31 Old 04-20-2012, 05:15 PM
Hillbilly Deluxe
Quoted: 2 Post(s)
My install will be started as soon as I get into my new house and garage(35x35), just closed yesterday.
I will have approximately $200 into my conversion. Areo reg and a 6.0 pump. Gonna be a deadhead design parallel to my wvo fuel system.
$700 is crazy...
Seth
Stroked_NY_023
post #8 of 31 Old 04-20-2012, 05:28 PM
StrokerIH's Avatar
i did mine a few weeks ago with a grand total of around $300 in it.
97 F250 HD, XLT, ext. cab. long bed, 4X4, E40D, 3:55LS, 3" DP, 4" MBRP, 5 1/2" tip, No Cat, No Muffler, E-Fuel, TS 6 pos chip, Front add-a-leaf, CAI 6637, Marinco Block Heater Plug, 265/75r16 transforce a/t, custom made mirror extensions, door keypad
StrokerIH is offline
post #9 of 31 Old 04-20-2012, 06:10 PM Thread Starter
Frostbite's Avatar
Quoted: 7 Post(s)
$300 and a days worth of work sounds fine.
$700 and a weeks worth of work is what I am trying to avoid.
post #10 of 31 Old 04-20-2012, 06:51 PM
I dont see how you can do it with 200-300 dollars without using used parts? New fuel pump-140$, regulated return sys-500, filters-110. All new parts and they are easily obtainable except the regulator.
