Pros and Cons to cutting off the catalytic convertor??? - Ford Powerstroke Diesel Forum
Old 04-04-2012, 12:49 PM
I have a 95' (doesn't need to be emission tested) that I have already cut the muffler off and put in a strait pipe in place....
Thinking about doing the same thing with the cat, chop it, strait pipe it. Am I going to gain anything??? I would think you would hear the turbo more (which I would like) and maybe get a little more response performance wise.
Any input would be great!
Old 04-04-2012, 01:04 PM
My kitty ran away the same day I got the truck...and took the muff with her.
You'll have less restriction, so perhaps a slight increase in performance and decrease in EGT. This will vary depending on how plugged up the cat is. Most noticable change for me was the amount I could hear the turbo.
Old 04-04-2012, 01:06 PM
gain sound and response, lose weight
Old 04-04-2012, 01:08 PM
You can always just take it off and smash all of the ceramic honeycomb out of it, then put it back on and you wouldn't even need to find a piece of pipe to take its place.
Old 04-04-2012, 01:29 PM
This works good.
Old 04-04-2012, 02:08 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
Originally Posted by Skew12 View Post
This works good.
I havent run one on any of my last 3 psd trucks. Slight performance gain, less exhaust resrtictions, better mpg's and turbo whistle.
IMO i.would do the DIY intake ($40), 3" DP ($90), kitty delete($20) at the same time. You be amazed how much it wakes your truck up. Like I said not much in the way of HP but you will gain alot of throttle response...
Sent from my SPH-D710 using AutoGuide.com App
Old 04-04-2012, 05:57 PM
I "gutted" the one on my 94. I would recommend just taking it off and saving it (they are ridiculously expensive) just in case they change the testing rules (I live in Cali and you never know). After I did it, I thought about it and managed to find a new takeoff Cat (off an SD) for $10 on ebay (it's sitting in my garage). Get (or make) a "test pipe". Cheers!
Old 04-04-2012, 08:46 PM
Perfect, bye bye cat! Thanks for the input.....270,00 miles...I can only imagine how that cat looks in side!
Old 04-04-2012, 09:26 PM
Send a message via Skype™ to OnTheBio
pros - sound, egt's
cons - sound.
Sometimes the noise gets incredibly a-noise-ing ah ha... ah ha ha
Old 04-08-2012, 12:05 AM
This^^
Also do FPR mod, clean fpr screen, and clean your fuel bowl and new o-rings.
Mine has been a night and day difference doing the intake, DP, exhaust, FPR mod, and clean fuel bowl and fpr filter. Very basic things will make a huge difference.
