trans temp probe - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-26-2012, 01:52 PM Thread Starter
trans temp probe
on a zf5 where does this probe i have go??? is it up high on the drivers side, i have something there with 2 wires coming out of it already?? any help would be great. they are glowshift gauges. truck is a 94.5 f350! thanks
leftyokie is offline
post #2 of 16 Old 03-26-2012, 03:29 PM
StrokerIH's Avatar
as far as i know there is no reason for a trans temp gauge on a manual trans. could b wrong though.
97 F250 HD, XLT, ext. cab. long bed, 4X4, E40D, 3:55LS, 3" DP, 4" MBRP, 5 1/2" tip, No Cat, No Muffler, E-Fuel, TS 6 pos chip, Front add-a-leaf, CAI 6637, Marinco Block Heater Plug, 265/75r16 transforce a/t, custom made mirror extensions, door keypad
StrokerIH is offline
post #3 of 16 Old 03-26-2012, 04:32 PM
Turbostang500's Avatar
Not many talk about running a trans temp gauge on a std trans.
If you want it, you would likely need to drill the drain plug and tap with a 1/8 npt tap.
i dont know if this would work for ya but i do know the thing would need to be down low so it was in the oil.
Probably just send that gauge back and get a fuel pressure gauge.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #4 of 16 Old 03-26-2012, 05:34 PM
erics diesel's Avatar
here is where another member mounted his
http://www.google.com/url?q=http://w...ipsNDpibyTsZ0w
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #5 of 16 Old 03-26-2012, 06:53 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
I had one on my 94. The ZF's do run hot, especially in 5th gear when towing. You can modify one of the PTO covers to take the probe (you want the probe immersed in the fluid) as in the link. I had a FabCraft Metalworks billet PTO cover to mount mine in (it had a couple of NPT-threaded holes). Before I sold the truck, I had thought about setting up an external pump and cooler for it (not a cheap endevour BTW ... just a Weldon or Tilton pump is $200-$300, throw in a good stacked plate cooler, braided lines, fittings, temp switch, etc and you get the picture). Cheers!
Patrick Feeley is offline
post #6 of 16 Old 03-26-2012, 07:22 PM
jesilvas's Avatar
Quoted: 2 Post(s)
What temps are you looking at normally? And what is the limit?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 16 Old 03-27-2012, 05:15 AM Thread Starter
thanks for the info guys. i couldnt imagine really needing it, but i came with it so i was going to try to install it.... i could see where the fuel pressure would be more help than tran temp... i do like the link that is a pretty clean set up, i guess i need to decide which way to go now... while im getting all this good info, what about the boost? where are you all installing the hose?? thanks again
post #8 of 16 Old 03-27-2012, 10:09 AM
I just put a tee in the map sensor hose.
i was worried about it leaking though so i used a small zip tie around each connection on the tee just like a little hose clamp. It works real good!
Lee
[/URL]
post #9 of 16 Old 03-27-2012, 10:12 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Drilled and tapped my spider
My Samsung SGH-I997 made me send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 16 Old 03-27-2012, 12:38 PM
Send a message via Skype™ to OnTheBio
This.
If you T off the MAP line it will shutter vigorously 5-7 lbs +/-.
OnTheBio is offline
