Gears?
Hey guys,
What do you think I should do for gears. Was bouncin the idea around with my buddy about 4.56 but i think ill settle for 4.11. Right now the trucks a sterling 10.25 with 3.55 gears, ZF5, and im rolling on 37" toyos.... great highway haha. I dont want to lose too much highway, and i also tow a decent amount.... and like to go fast ![]() What do you guys think? How do you work out what RPM id be with different gears? Which is the best online vendor for gears? miaswell swap a posi in? Cheers!
I would do 4.30, that would be like running 3.73 with stock tires and should give you a good balance between MPG and towing.
I run 4.10s with 35s. If I was to go to 37s I would re-gear to 4.56 but I also run in some pretty steep mountain terrain.
I run 4.56s with 37s in my 01, i am ok with them, i wish i woulda went with 4.30s though, alil better on the highway but i dont drive much highway thou so thats ok.
Just depends on how heavy of towing your going to be doing really?? If not that much i would just throw a set of 4.30s and call it good |
That truck is lookin mean as hell!
I am running 37" BFG MT with 4.10's and turn 2k at 70mph. I also tow a 4 & 5 ton excavator without any issues.
I also am getting 20-23mpg hand calculated... Sent from my SPH-D710 using AutoGuide.com App |
im running 35s and 3.73, makes a great highway truck but a little dogish for towing, uses to have stock tires a 4.10 which towed like a horse in comparison. i run 2k @70mph and will tow much better when i get somesupporting mods to help out!
so if your lookin at 37s,i would go with no smalller then 4.10s, will put you at around a 3.55 or so, all depends on how much you tow? |
Thanks for all your input! I tow a dump bed for work, tow a boat with a camper loaded too. Where is the best online vendor for gears? Any suggestions for a posi/LSD?
I like Randy's ring and Pinion Home Page Do you still have a tag on the rear pumpkin? If it does and the second letter is a L then you already have a LS.
