Hi, I have been reading about the E4OD torque converter lock up mod and was wondering if anyone here has done it. I've heard that it can improve transmission life and other things but I wanted to talk to someone who has actually done this. Is it that difficult to do? I have seen some wiring diagrams and several different ones at that. I will post some of them below for those of you who are interested. I know someone that has done it locally all they said was that it is worth it, he had not installed it, he had someone put his in. His transmission is at 450K and still climbing. Let me know if you have done this or if you have experience with it.
Here are some of the wiring diagrams: E4OD torque converter manual control (off-lock).pdf E4OD torque converter manual control (off-auto-lock).pdf E4OD torque converter manual control (auto-lock).pdf ( If you have problems opening them try using Adobe Reader) |
Cant see the diagrams... What is the mod? Lock up switch? Sent from my SPH-D710 using AutoGuide.com App |
I was hesitant to believe about the 450K until he showed me, he did and I believed him. Yes it is the lockup switch. I wasn't sure if the diagrams would open or not. Might have to be using some sort of computer I am pretty sure. Here is the link they are located, you'll have to scroll down a little ways to see the discussion. E4OD Torque Converter Lock Up Mods |
So he showed you the odometer? That dosent mean there is 450k on the tranny. ANY auto Trans has wearable parts. They just arent designed to last that long. He either has no idea what The milage is or he is bullchiting you. Its just not possible...
As for the mod it can be done, pullers do it all the time. Its not really a daily driver mod though... The tc is designed to have slippage... The same as easing out the clutch on a stick... Not sure what you goal is? Sent from my SPH-D710 using AutoGuide.com App |
Well my goal is to see if anyone has used this and if it was beneficial to them in the long run.
ive read about others doing this only for slowing down a trailer easier and keep it locked so as not to overheat, but ive been wanting to do one along with an exhaust brake mod, i dont beleive the factory lasting 450k kause of this mod tho
im skeptical of the mileage aswell the lockup switch is actually a good idea if used on the highway or at cruising speeds imo i have used this same mod on many 700r4 build classic chevys and it was only used to keep the transmission temps down while cruising at highway speeds the torque converter will have some amount of slippage the lockup provides a means to completely remove the slippage at cruising speeds whick will help keep the trans temps down but for anything other than that the lockup will hurt you because the converter provides torque multiplication at the expense of rpms so if you did use it i would only use this mod at cruising speeds to reduce trans temps
it would do exactly that but it will work against you in stop and go traffick cruising at steady speeds you should use something like that what you haul in or on it makes no real difference im sure your not lacking power to where you will need to downshift so no worries
Sent from my DROID RAZR using AutoGuide.com App |
