installing a Chip - Ford Powerstroke Diesel Forum
Old 03-12-2012, 11:33 AM
installing a Chip
Anyone know of a vid or write up on installing a chip from inside the cab by removing the E-brake?
Old 03-12-2012, 12:51 PM
No real need for a vid or clip. I just did mine, it is three bolts, 13 mm i think. E brake comes off computer is right there. Disconnect battery. Pull off the black plastic piece. clean the board, scratch lightly with screwdriver, wipe with thinner, I used alcohol and a q tip. Install chip, slides right on. If it is a 6 pos ts then route your switch to were you want it and enjoy. Took maybe 45 minutes.
Old 03-12-2012, 02:49 PM
Probably much easier than going through the fender. I did that a month ago and a real PITA. Good luck!
Old 03-12-2012, 03:27 PM
I have only installed one chip, but I took the pcm out, it seemed like a lot better way to me to make sure everything was clean.
Old 03-12-2012, 03:39 PM
pulling the pcm is the best way. i took mine apart and re-tinned the contacts on the board. works flawlessly. u won't have any problems of "did i clean them enough" ?
it only takes a couple of minutes to pull it - use a prybar to "persuade" the inner fender a little out the way and it slides right out.
Old 03-12-2012, 03:52 PM
Old 03-13-2012, 04:05 AM
Thanks Rob,when I installed the Bully Dog chip a few years ago,I cleand and scuffed the plug so I know it's free of silicone and clean,The under the hood method is a real pain so I figured the E-brake method should be less stressful.
