exhaust housing removel !!! - Ford Powerstroke Diesel Forum
Old 03-09-2012, 03:17 PM
i have a 95 psd and im trying to remove the exhaust housing and replace it with a .84 i have all the bolts off the pedistal have the down pipe loose and the piece that connects the down pipe(not sure what its called) the y pipe is out. but all the bots are out to remove everything except exhaust housing manifold ots i cant get the the two on the bottom ive tried everthing swivel socket small 15mm wrench tried to even weld a 15mm wrecnh head on a extension and i cant get it off does anyone have write up on this
Old 03-09-2012, 03:41 PM
If you take a 15mm wrench you don't like you can heat it up and bend it so it fits around the collector. You have to keep the box end to make it work. This is what mine looks like, it works good for me.
Old 03-10-2012, 03:44 PM
Okay I'll give that a shot and see what happenes thanks man. Has anyone ever put the .84 housing on there truck with just a chip intake a exhaust ? Did it perform better less lag in te turbo ?
Old 03-12-2012, 04:44 AM
Too cool for school
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
I have one on mine. Its great with stock injectors. Less lag.
Old 03-12-2012, 08:49 AM
ive been wanting to do this too but most people suggest going with a 1.00 housing instead. ive heard that towing with the .84 your egs can get hot. not sure why because as far as i know the superduty 7.3 has a .84 stock but its wastegated if that makes a difference
Old 03-12-2012, 11:31 AM
Too cool for school
I've never been above 1000*
Old 03-13-2012, 05:16 AM
even towing, if so how much weight and in what climate? what other mods do you have?
im just saying i want to do this but was advised by ct performance not to use a .84
Old 03-13-2012, 05:49 AM
Too cool for school
Towing a Ford 6610 loader, 40hp tow tune. Do it only if you plan to stay with stock injectors.
Old 03-13-2012, 08:46 AM
I have this housing and i pulled a load of pallets and the hottest i saw was 1100 going up hill. Weather was about 50* here that day
Old 03-13-2012, 05:49 PM
Too cool for school
Hey redrifle what tire/wheel combo is that?
