Turbo Decision
Hey guys, I'm deffinatly going with the 66mm H2e but im alittle worried about the intercooler install. Can i get some tips on how to mount it and what not? Im about certain im just gonna grab a 6.0l intercooler from a local junkyard, sound ok?. Also do i need to get 3 inch plenums? I was told I do and would just grab them at the junk yard while i was there if i do need them.
Here is my current mods wish list..... Look ok to yall? Horsepower estimates? 1. 66mm H2e 2. RevMax Stage 4 T/C 3. T-500 (Possible could get a SRP1.1) 4. Beans fuel system 5. ARP head studs 6. Comp Cam 910 valve springs |
And one thing i forgot, when i have my DP reburnt can i just have them tune for the mods i plan on but have not already installed?
this is a great write up, by the way i think if your going with bigger injectors the 6.0 wont flow air fast enough i thought i read this some where but i can be wrong. just make sure you do your research
6.0L intercooler install in '92-'96 body |
6.0 intercooler sounds good.
What are you doing as far as an intake spider (manifold)? Modding your existing y-pipe? Getting an E99 spider? Buying a Banks kit or similar? Late 99-03 spider and deleting the fuel bowl? The first three options will let you keep your 2.5" intake plenums. Late 99 spider will mean changing over to 3" plenums. |
The pipes and everything is included with the kit from CT performance
If you're going with a kit designed for an OBS it will be designed around the 2.5" plenums.
Id add some upgraded push rods to that list of mods u got there. with the 238s u have listed in ur sig and combined with these mods and some good tuning i would think u should make 450-500hp. look into a s300 turbo charger lot more options there.
that s300 (with thoes injectors i would go bigger like a S400) would require a T4 mount kit from Irate.... but will create endless possibilties later on down the road!!!
Wait isnt the S300 a T3 mount??? or are there different ones??? |
One thing to keep in mind, that 6.0 IC has plastic end tanks. You didnt mention what you were planning for injectors, if you are staying small, which I doubt given the turbo you are looking at, the 6.0 IC will be fine, but any injectors stage 2 and above will easily run you over 40 psi of boost and the all aluminum IC will work alot better for you.
Just something to keep in mind. Edit: I just noticed you did have the injector choice listed....I wouldnt be putting a 6.0 cooler in there, you will make more than 40 psi and the plastic tanks wont be liking that |
