water/meth injection - Ford Powerstroke Diesel Forum
Old 02-15-2012, 03:50 PM
I just installed a 4 inch turbo back exhaust,ts 6 pos programmer & cold air induction on my 96250,was wondering about the water injection, is it worth it and if so what system do you guys think is best
Old 02-16-2012, 11:35 AM
Send a message via AIM to High7echRedneck
I would upgrade the intercooler instead. There can be some bad side effects to the water/meth method. The intercooler method is also better, performance-wise.
Old 02-16-2012, 05:15 PM
water meth will get you more power and its a better bang for the buck. Intercooler is nice cause its always there and you never have to refill it.
Old 03-23-2012, 11:50 PM
Young diesel enthusiast
ive had water/meth a long time and i love it
Old 03-24-2012, 02:58 AM
Can you feel a power gain when it clicks on? Also what % are you running and how loud is the pump
Old 03-24-2012, 01:55 PM
Send a message via AIM to baderic03
pump is quiet mounted in the engine bay or under the truck some where i would run a 50/50 or 60/40 mix as far as kits go go with s snow performance stage2 with addleast a 2gal tank
Old 03-24-2012, 04:38 PM
yes pump is quiet and my pump is turned up all the way im not sure what psi and ive ran as much as 70/30 but never more than that and you can definitely feel the power increase but it also depends on what mods you have with it
Old 03-24-2012, 05:23 PM
I'd be afraid to run water/meth. I mean, you're injecting water into the engine, won't that cause rust or anything? Or is it such a little amount it burns up before it can so anything?
Old 03-25-2012, 08:44 AM
It's minimal amount it cools egt a couple indeed degrees on application
Old 03-26-2012, 08:19 AM
QUOTE
---I'd be afraid to run water/meth. I mean, you're injecting water into the engine, won't that cause rust or anything? Or is it such a little amount it burns up before it can so anything?------
All those kind of questions are already answered on snowperformance.net
