Help with intercooler - Ford Powerstroke Diesel Forum
Old 02-12-2012, 07:54 AM
I am a new owner of a 97 power stroke and am looking at different things to make it run better. My first question is what kinda intercooler should I put on if any. I have a ts 6 position, intake, straight pipe and boost relieve value. Also as I reading this what is the obs thing that I see people talking about. I'm also thinking about meth injection. I'm just waiting for my buddy to finish his first. Any help would be awesome.
Old 02-12-2012, 07:56 AM
Also I changed my oil and down the front of my transmission there is a fuel leak. I'm not sure where it is coming from
Old 02-12-2012, 08:06 AM
Full A-Team Member
OBS refers to year of truck, 94-97.
Why do you have a boost relief valve?
The fuel leak is in the valley of the engine, there is a drain in the rear of the valley that makes it run out by the trans
Old 02-12-2012, 08:15 AM
It came with the chip package i bought. Why does it drain out though I feel like that is not right
Old 02-12-2012, 08:16 AM
Delivers Pizzas For Fun!
i belive i may have that same fuel leak.... is just slight to make a few drips every now and again depending if its running and warming up or shut off. when i warming up i get a little bit more then a few drips. it makes the truck smell of diesel
Old 02-12-2012, 08:21 AM
That is my same problem I'd like to fix it if I can
Old 02-12-2012, 08:32 AM
Full A-Team Member
Yes its a leak, look around by the fuel bowl
Old 02-12-2012, 08:54 AM
Ok cool thanks does anyone have any input on my inter cooler post as far as it being worth doing it
Old 02-12-2012, 07:19 PM
It depends. Do you have gauges?
If your EGTs are too high one might be a good idea. An intercooler dropped mine by about 150-200 degrees. Yes, they help build more power by introducing cooler air.
Old 02-12-2012, 07:22 PM
with the mods done to your truck now you should be fine with out a intercooler but if you want to start pushing bigger hp im would suggest doing putting one in
