Best E4OD Mods - Ford Powerstroke Diesel Forum
Old 02-08-2012, 07:18 PM
Send a message via MSN to 95_Powerstroke
Best E4OD Mods
I plan on throwing some HP at my truck later on and so i want to build my trans now. I don't have the funds for a BTS trans as much as I want one. I plan on doing a BTS valvebody, V10 transcooler or whatever else someone recommends, and a full service. What torque converter should I go with or should I just leave it stock? Thanks for any advice.
Old 02-08-2012, 07:25 PM
Torque converter is a weak point on these, some are saying use a 6.0 converter. When I had my trans done the builder used a towing converter from roadrunner out of Phoenix.
Old 02-09-2012, 07:02 PM
How much would a 6.0 converter run? The one I was looking at was the ATS 5 star for about 1400. Thanks for the reply.
P.S. What did you use for a cooler?
Old 02-09-2012, 07:08 PM
The converter I used was over $200 I believe and I spent a extra $500 on a deep aluminum pan and tru-cool cooler
Old 02-09-2012, 07:15 PM
I should add that I didn't feel the need for ultra expensive transmissions or converters since my truck is mostly a daily driver and occasionally tows up to 10k. If I was towing a lot more often and a lot more weight I probably would have spent a little more on it.
Old 02-09-2012, 07:32 PM
I ask Brian at BTS about the deep aluminum pan and he said he didn't
care for them, because once all that oil gets warmed up, it's just that
much more oil to cool.
Do your research and get the best torque converter you can afford.
Doug
Old 02-09-2012, 09:15 PM
Yeah, I have heard the same thing about the pans. I was not planning on getting one. Just a VB, TC, and cooler. I have heard that I should not get a TC unless I have a built trans which is why I was asking for opinions.
Old 02-09-2012, 11:53 PM
drives a ranger
Send a message via AIM to kanuck15
best automatic trans upgrade is a 5 speed. Unless you can afford a BTS dont even bother patching a trans that needs work. I doubt your trans is original with that many miles but still id hold off till you can get a BTS or a 5 speed (big vote for 5 speed swap)
Old 02-10-2012, 05:43 PM
What torque converter do you recommend? I am in the same boat.
Old 02-10-2012, 06:34 PM
Another thing to consider is a bypass style trans filter
