turbo q's - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-08-2012, 11:44 AM Thread Starter
Question turbo q's
Can someone plz tell me the pro/cons of hitting the pedestal? And if anyone can tell me the good/bad when it comes to the exhaust housing from a 1.15 to a 1.00 thanks.
Dmfs90 is offline
post #2 of 16 Old 02-08-2012, 11:45 AM Thread Starter
Not hitting. Gutting
Dmfs90 is offline
post #3 of 16 Old 02-08-2012, 11:57 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
slightly better flow if you gut it, and you loose the ebpv if you do as well, warm up takes slightly longer tho, but not a huge deal, and if you go to a 1.00 exhaust housing it will spool faster but have slightly higher egt's
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 16 Old 02-09-2012, 11:38 AM
Quoted: 77 Post(s)
The biggest reason we gut or install a blank pedestal is to get rid of a huge potential oil leak. The extra plus is ever so slightly lower EGT's from removing the ebpv that is a slight exhaust restriction. I saw absolutely no difference in EGT's from installing my 1.0 turbo housing and sure like the faster turbo spooling.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 16 Old 02-09-2012, 11:50 AM Thread Starter
Ok so if I gut the pedestal and add the 1.00 housing then the egt's should stay about the same. It's all stock rite now. Has 230k its a 5spd. Any other mods besides 3" dp and intake/exhaust?
Dmfs90 is offline
post #6 of 16 Old 02-09-2012, 12:08 PM
Quoted: 77 Post(s)
I would say that IF the egt's change it would be slightly. I did see increased performance with the 140v idm mod. You should get egt/boost gauges before doing any mods. Absolutely do the intake such as the 6637 and 3" downpipe. You should also think of some kind of chip whether it is a superchip like I'm using for now or a multi position chip to get the most from your engine. I have seen the blank pedestals for as low as $140. If you are going to do all the work of pulling the turbo to change the pedestal and or the exhaust housing I would consider having the turbo rebuilt. Guess I should add there are lots of mods you can do, it's all in how much horsepower you want and how much money you want to throw at it. Things like bigger turbo's, bigger injectors, water/meth injection, propane injection, intercooler, the list goes on and on.
Jack
322000 miles
post #7 of 16 Old 02-09-2012, 12:27 PM Thread Starter
I don't have any knowledge about chips what is a decent mod as far as that goes. Plus how hard is it to install those gauges? . Im not going to co crazy with hp. It's a 96
Dmfs90 is offline
post #8 of 16 Old 02-09-2012, 12:37 PM
Quoted: 77 Post(s)
Here is just a couple links for chips, there are several Diesel tuning products for Ford PowerStroke http://www.swampsdiesel.com/xtcommer...---Tuners.html
http://www.tonywildmanchip.com/
Gauges are not hard to put in, hardest part is drilling and tapping a exhaust manifold to install the egt probe.
Jack
322000 miles
post #9 of 16 Old 02-14-2012, 04:37 PM
Diesel Freak
yngbuck19's Avatar
Oh man don't lie to the guy that was the easy part wiring and finding a way through the fire wall was the hard part along with getting it all to fit back together on the pillar and look nice jmo
1997 F250 7.3 powerstroke SCLB HD XLT
340,000 Mi.
Blown Tranny Mod
D60 Swap
4:10's
DIY E-FUEL
PHP 6 pos.
S&B CAI w/Prefilter
EBPV Delete
3" DP
Kitty Delete
Cat Back 5"
Aeroturbine 5050XL Muffler
6" Vented Tip
S.S. HPX
17"X10" Pacers
4" Rough Country Susp. Lift
KW 17 LED CabLights
35"X12" BFG KM2's
Tint 20%
Magnum CB 104" Whip
Quad A-PillarPod
GlowShift Digital Gauges
Future mods: ??? 1.5 Sticks T500
1996 ECLB XLT SOLD
1997 ECLB HD SOLD
yngbuck19 is offline
post #10 of 16 Old 02-14-2012, 04:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
hell there is a hole just left of the brake booster, has a black oval ish plastic plug covering it, it pops out and easy to run stuff through, just make sure you run the probe first, kause the egt probe wont fit with all the wires in the way, hardest part is making it look nice and getting it to where you want it on the a pillar,
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
