Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
Old 09-14-2007, 10:26 AM
squeeks squeeks is offline
DIY-Injectors Stage 1 or 2
I have been looking at getting a DIY Kit for my injectors but i am not sure which kit to buy. Stage 3's are way too expensive for me right now, so i have been looking at Stage 2 or 1's. My question is Stage 1 and 2 supposively they both flow 160cc's so what are the benefits for getting Stage 2's vs Stage 1's.
Thanks
Old 09-14-2007, 10:28 AM
FionaThe02PSD FionaThe02PSD is offline
Are they both splits or singles?
Old 09-14-2007, 11:16 AM
lilredpowerstroke lilredpowerstroke is offline
Powerstroke Pimpin'!!!!!!
Get the Satge 2's unless you really want the 3's then wait and save up some more money. If you get the 3's get the single shots since they use less high pressure oil to fire. The difference between the 1's and 2's if they are both single is the 2's have a lot bigger nozzles
Old 09-15-2007, 02:59 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
you have to stick with single shots, that's what the OBS trucks use. The larger nozzles are supposed to be good for an extra 50 HP. You will probably need an upgraded HPOP to get the extra power out of the stage 2's. Stage 1's are great, but if you plan on adding more power, go with the 2's. You will want a larger turbo also. The hybrids are nice, because they use stock HPOP pressure to give more fuel. You will need many other mods to run 'em.
With any injector upgrade, you should get a custom chip.
Old 09-16-2007, 03:32 PM
I was definately going to get my chip reburned by tony, i already have the 17* hpop do you think i would have oil problems if i went with the stage 2's.
Old 09-16-2007, 03:35 PM
Maintain Maintain is offline
1/4 mile shot
Send a message via AIM to Maintain
Stage 2's and 17* should work decently.
You can always go big oil later!
Old 09-16-2007, 09:13 PM
Stroked95 Stroked95 is offline
Sqeeks, my recomendation is to go to 2's or go as big as you can afford. With 2's you should see 400hp, maybe more. With the 17* pump and tony's burns you should be good to go. If you don;t have it already look into getting a fuel system, and turbo, I know alot of guys are happy with beans D66 turbo. Good luck modding
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
