Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
  #11 (permalink)
Old 09-13-2007, 08:30 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
hrmmm... well the water meth can kinda do the same by adjusting the amount of water to the amount of meth
either run 100% water to cool EGT's or run 50/50 for HP or anywhere in between to do a little of both... all I know is with his tuner and water/meth injection - he was getting better mileage in his 4wd Excursion that I Was in my 2wd F250
  #12 (permalink)
Old 09-13-2007, 08:40 PM
Mavsps Mavsps is offline
I agree with blue..... if you decide to run the pane just be prepared for the conciquences, but all in all its up to you. Personally I wouldnt but thats me
  #13 (permalink)
Old 09-13-2007, 09:54 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Another forum guy could not keep compression. He had run propane for around 60K and it cracked the block like a spiders web. I believe this is referred to "widowing the block". Most of the guys that have run propane have ditched it due to cylinder pressure issues.
More than 40% meth with water will do the same thing. If you want pure fuel economy, the best control over that is tunes and the right foot. For power, use water to cool the turbo so you can run it back to max with more fuel.
If you are going to install the propane and run the afore recommended 50/50 water meth mix, Keep us posted on when you start the rebuild......
  #14 (permalink)
Old 09-17-2007, 08:07 PM
BroncoDiesel92 BroncoDiesel92 is offline
Yea well I don't have a choice right now I need to sell the propane kit for the cash to finish the install of my motor into my Bronco. So it's not an option anymore unless no one buys it.
  #15 (permalink)
Old 09-17-2007, 08:14 PM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
u got propane and water/meth? see wut else u can fit in ur truck to. get nitrous and the waste veggie and see if u can get a 4 toggle switch
  #16 (permalink)
Old 09-17-2007, 10:08 PM
I wish I could, I am being forced to sell the propane due to a cash shortage. I need the cash to finish my bronco first. I cut the firewall today so the motor can sit correctly in the engine compartment, so tomorrow or some time this week I should be able to have the drive train in line and ready to go. I will keep you guys posted.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
