E4OD rebuild kits???? - Ford Powerstroke Diesel Forum
Old 01-30-2012, 11:57 AM
My son's truck finally spit out the transmission. It has developed a problem where once it warms up, it won't shift out of 1st. The OD light is NOT blinking, no codes, and it heats up fast. This past weekend, he pulled the pan to find some metal pieces. Cleaned the pan, blew out all thelines and coolers. It is still doing the same thing.
Now, we are pretty handy when it comes to our trucks. He swapped a 96 engine/tranny into his 94.5 effectively converting from manual to auto. He swapped dashes, the harness, column, and everything else required for the auto to work. It has worked fine for months now. It just started acting and now that we have some carnage, it is time to rebuild.
Sure a BTS built transmission would be awesome. Paying for it is not so awesome.. So, we decided to attempt to rebuild it on our own. He has quite a few mods done to his truck (and he did them all himself except building the injectors), intercooler, hybrid injectors, twin superduty pumps. This thing screams... We want to make it as bulletproof as possible. We have been poking around on the web and there really isn't much out there. I guess most backyard mechanics don't want to attempt a rebuild. We did find this site that offers a Stage 4 Enforcer kit... E4OD, 4R100 Transmission from PATC, E4OD, 4R100 at $1500 it seems pretty good, but my son did some research and found alot of negatives and positives. Most of the negatives were from the rebuilds that company did. There are a few kits on ebay. We just need some direction on where to get the parts and the best parts to get.
I figure as long as we take our time and go through the manual, we shouldn't have any problems. If it takes a month to do, that will be fine.
Come on folks, give up some knowledge....
Old 01-30-2012, 08:00 PM
If you've got the funding, check out the kits from John Wood Automotive (he, like BTS, is also highly regarded). Another option would be kits from RacerX. Cheers!
Old 01-30-2012, 09:48 PM
This place has some good deals on parts and upgrades
Ford RWD Transmissions E4OD, 4R100 Transmission Parts Makco Transmission Parts
Plus you are gonna need a couple of tools to assembly the trans. The two most important tools you are going to need is to install the center support T-2804 -Ford- Clutch Spring Fixture- Metal [E4OD] and the one to install the intermediate brake drum assembly, foward clutch assembly and input shell assembly as one unit T-2805 -Ford- Clutch Drum / Shell Assembly Remover-Installer [E4OD] and making sure the pump halfs get put together square. Other than that overhauling an E4OD is pretty simple
Old 01-31-2012, 07:18 AM
Thanks... That is what I was looking for. Are those the only two tools I will need to accomplish this rebuild?
Old 01-31-2012, 05:12 PM
You will need a really big hose clamp to assembly the pump halves similiar to this T-2862 -Ford- Front Pump Alignment Band [E40D] ,two bolts with the heads cut off to align the pump in the case and one of these to take the clutch drums apart
Amazon.com: OTC 7024 Automatic Transmission Clutch Spring Compressor: Automotive Amazon.com: OTC 7024 Automatic Transmission Clutch Spring Compressor: Automotive
Old 01-31-2012, 05:56 PM
I ordered the enforcer 4 kit along with new bushings, thrust washers, and bearings. I also ordered the first two tools. I thought about the one you posted above and should have ordered it too. There is a nice writeup on rebuilding the e4od and this guy says he could have used a couple c-clamps and a pipe flange to accomplish the same thing.
E4OD rebuild
Old 01-31-2012, 07:26 PM
I used 2 really big hose clamps and a couple of drill bits to line everything up
