Really want stage 1's but dont want to fry my auto tranny... - Ford Powerstroke Diesel Forum
Old 01-29-2012, 03:11 PM
1996 dually auto with rebuilt tranny about 8k miles ago... with valve body and tc in it but thats it for the tranny and all i want is injectors... got all the supporting mods but will need to send in my 6 pos for a reburn if i get them.... can i put 350 down to the wheels with stage 1s
Old 01-29-2012, 03:18 PM
350 is about the limit of stage 1s if I remember correctly. what supporting mods do you have?
Old 01-29-2012, 03:22 PM
Intake, exhaust, ts 6 pos, and was thinking about hpop but i hear you dont need it to get the stage 1s full potential... couple of other little things i am leaving out... triple gauge set up
Old 01-29-2012, 03:41 PM
the baconator
it is
you will need a good fuel system and a good HPOP
I would suggest both a 17* HPOP and e fuel
Old 01-29-2012, 03:47 PM
Full A-Team Member
If you are doing this to your 03 you wont need a different HPOP....
Old 01-29-2012, 03:52 PM
the baconator
1996 dually elmo
Old 01-29-2012, 03:58 PM
Full A-Team Member
so used to just looking at peoples sigs to see what they are working on
well, everything has already been said.
Your trans will pretty much be fine with 1's with whats done to it.
350 hp is a stretch, the best tuners with the best mods and best equipment can get 350, but it is possible with 1's
Definately need the HPOP, the stock 15* wont do it, it will run, but not nearly to what the 1's can do
The stock fuel system is fine, but electric is always good
for the most hp, make sure all supporting mods are done to get all you can out of the 1's
And, you already have the plans for the chip
Old 01-29-2012, 04:02 PM
CSP Resident Spooby
I think Mike hit 376hp or something on Stage 1's didn't he? I've heard of people making more too. Hell I'm probably hitting about 350 hp, comparing it to other trucks I've seen with similar mods. I'd like to put it on a dyno now that I have the T500 in.
As of last night I can highly recommend a modified HPOP. My truck pulls harder now, even with a boost leak. I have a STOCK reman tranny with roughly 40k miles on it, and it's holding fine... for now
Old 01-29-2012, 04:12 PM
the baconator
yes he did. i am not sure how accurate the dyno are. people like big HP numbers and dyno owners/operates might skew the numbers a little bit. I think track time and weight will give a better HP number
Old 01-29-2012, 04:14 PM
CSP Resident Spooby
That it true. It's tough to get consistent HP numbers from different dyno's.
