Inner Cooler Install on A 96 - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-17-2012, 07:42 PM Thread Starter
Crusader Kid's Avatar
Finally got around to putting the inner cooler in on my 96 F-350. Have had the parts for almost a year. Got the 6.0l cooler for free, the E99 spyder for $100, the pipes for $200, 2ft piece of silicone hose for $50, and 1 factory hose for free.
The disassembled front end
The pipes and hose
The cooler
Core support marked for the inner cooler
Brackets made for AC condenser
Spyder Installed
Support Straightened
Brackets paint for final install
Cutting the holes in the core support
Test fitting the cooler
Brackets welded and painted
Had to have one pipe fixed.
Final install of the inner cooler
Still have to install a couple of clamps, Mount the trans cooler and put the front end back together. More pics to come
96 F-350 PSD 4X4 Crew Cab Long Bed, Superchips programmer, exhaust, HPOP crossover hose, trans, pyro, boost gauges
76 F-250 460 4x4 long bed
66 F-100 302 4x2 stepside
07 F-150 5.4 Crew cab 4x4 w/ 6.5ft bed
Crusader Kid is offline
post #2 of 20 Old 01-17-2012, 09:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
looks great, very professional looking, looks like when i started my install, winch wouldnt let me keep it tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 20 Old 01-17-2012, 09:38 PM
svranger25's Avatar
nice job man, i have a inner cooler as well but was wondering about a trans cooler as you said you were mounting one, where at cause i read on a different thread that it was difficult to mount because of lack of space, details on how you plan to do this would be much appreciated.
-Brandon-
1996 F 350 7.3L CCLB
6637 Intake; Banks: Intercooler, Up Pipes, Turbo; PHP Phoenix
4" down-pipe, cat delete,muffler delete, 4" turbo back exhaust
Sky Jacker Suspension, Limo Tint, Cobra Classic 29 LTD,
Stage 2 TC, improved internals
Loudest, Proudest member of the Fightin' Texas Aggie Class of 2015!
svranger25 is offline
post #4 of 20 Old 01-17-2012, 10:10 PM Thread Starter
Figure the trans cooler is gonna go on the headlight support that the grill bolts to.
post #5 of 20 Old 01-18-2012, 07:04 AM
Full A-Team Member
Fordman247365's Avatar
Trans coolers fit fine, when you go to a bigger trans cooler, you just cut the center out of the header panel
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #6 of 20 Old 01-18-2012, 02:54 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
could go to a tru-cool maxx and mount it in the bumper.. they are good coolers and have a small but thick design
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #7 of 20 Old 01-20-2012, 07:05 PM
i want to do this but like 351fifty i have a winch and bumper. Are there any alternatives? Smaller IC?
1997 F350 SRW RCLB, 4.10s, RSK 4" on 37" Toyo M/T's, Tony Wildman 6 Pos., 3 Pillar Gauge Pod with Trans Temp, Boost and EGT's, BTS Valve Body, AFE Intake, 3" DP to 4" to Dual 6" Stacks, Custom Front Bumper, 12k Winch
Project 5 Speed soon to Come
s.hiles is offline
post #8 of 20 Old 01-24-2012, 08:12 PM Thread Starter
Finally got around to finishing it up. Got the headlight support on
Grill is installed
Had to weld brackets to the bumper mounts for the trans cooler
Got the trans cooler installed
Bumper is on
Got take the truck to a buddies and gonna have build a splash shield for the bumper to protect the trans cooler lines and bottom part of the inner cooler
post #9 of 20 Old 01-24-2012, 08:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
looks awesome, i like the trans mount location, just makes me want a welder in a bad way, i may eve build my own bumper for the winch at that point lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 20 Old 01-25-2012, 04:02 PM
ol_Blue97's Avatar
welders arent that expensive Kris.... saw a 110v lincon MIG welder at home depot with the gas hook up for like $550. small stick welders are like $200 or less
intercooler looks great... i like how you took the time to mount it properly, was there any way to mount the intercooler higher to allow more air thru the grill to get to it? or does that make the pipes come thru to high?
FRANK THE TANK
