zf6 swap into 96 f350 crew long bed - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-24-2011, 09:28 PM Thread Starter
sscustoms's Avatar
hopefully someone out there has an answer for me,
i have a zf5 currently,
will the zf6 out of a 99-06 bolt up?
any suggestions on how to do this right?
sscustoms is offline
post #2 of 13 Old 12-25-2011, 06:40 AM
sgt dave's Avatar
Quoted: 3 Post(s)
The only difference is the zf6 has a lower first gear ratio. The final drive ratio's are almost the same. And there is a bit of fab work for the clutch pedal assembly. Hope this helps. Merry X-mas
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 13 Old 12-25-2011, 07:07 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
look this over... some people say its not really worth the trouble but the ones that have i never say they dont love it. the only problem with the swap is the ZF6 shifts horriable compared to the ZF5 and if you get a close ratio ZF5 there really isnt much diffeance with towing
Auto(e4od) to SD manual(zf6) build thread
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 13 Old 12-27-2011, 02:35 PM
wags's Avatar
they are just closer ratios
1997 F250 5-speed 4x4 7.3L PSD, 10k mod. built transmission, heavy duty gears and sycros,3 inch down pipe with 5 inch strait pipe, 6637 intake, and new fuel pump, baby swamps stage 1 150cc injectors, beans custom tunes on TS 6 postions, boost gauge and egt gauge
SOON TO COME: electronic fuel system. upgraded hpop, and gauges.
wags is offline
post #5 of 13 Old 12-27-2011, 04:25 PM
Full A-Team Member
Fordman247365's Avatar
If I had em both layin on the floor, I would put in the ZF6, just cuz it dont belong
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #6 of 13 Old 12-27-2011, 04:53 PM
Shade tree mechanic
95dieselsmoke's Avatar
I like your way of thinkin
MATT
Now featuring a 6.4 fat bottum 6 speed
95 f250--238k and counting
RDS stage I's-TW live tuned-Dana 60 swap-9" lift/40x13.5x20 ProComps-ZF5 swap/short throw/South Bend CON OFE-Iron Bull front-AFE CAI-SD innercooler-Fab Tech traction bars-MBRP DP/6" black miters-Autometer boost/pyro
"If you dont have ambition and big dreams, you end up working hard for someone who does"
95dieselsmoke is offline
post #7 of 13 Old 12-27-2011, 04:57 PM
Full A-Team Member
And as easy as it seemed in the link from Frank....might have to keep an eye open, that would be my new favorite mod
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #8 of 13 Old 12-27-2011, 05:07 PM
ol_Blue97's Avatar
^^^^ agreed..... it doesnt belong and thats whay we do things... when my auto trans blows a manual transmission is going in and i belive im gonna do the ZF6 swap myself. the one hurdle that i dont wana do is i belive you need the SD t-case with it and it just makes more parts that you need to buy. im not sure if that was mentioned in that link
also with the crossmember i hve heard that if you take the auto one and flip it upsidown and move it with new holes and bolts it will work??? but not positive on that, never seen it
FRANK THE TANK
post #9 of 13 Old 12-27-2011, 05:11 PM
Shade tree mechanic
Negative, when I made the swap there was no way in hell the same crossmember was going to work. Maybe it is different with a zf6 though
MATT
post #10 of 13 Old 12-27-2011, 05:20 PM
ol_Blue97's Avatar
does that mean you have done it.... i just wana know how it shifts??? like a tractor trailer or just a bit slower the a ZF5?
FRANK THE TANK
Tags
transmission , zf5 , zf6
