Best E4OD Shift Kit? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 06-28-2011, 07:40 AM Thread Starter
Ok so i have a stock E40D tranny. It is a Jasper that has been in the truck for less than 10k. Looking to get a shift kit for it and not sure what to get. Also will the shift kit harm the tranny at all?
I plan on either gettin a cooler or deep pan for it very soon too.
Kits ive found:
Jet Part 70704 - Jet Power Shift
Bully Dog Shift Enhancer #151000
s.hiles is offline
post #2 of 24 Old 06-28-2011, 08:01 AM
kylev90's Avatar
Quoted: 4 Post(s)
Banks Power TransCommand
Little more expensive, but seems like everybody is having good luck with these. It will actually help you control everything and keep truck in higher RPMs longer for towing or beating on it. The others seem generic.
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
post #3 of 24 Old 06-28-2011, 10:17 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
IMO and also BTS never use a Trans command. Either get a kit and mod the VB yourself of for the best results a BTS or JW VB set up for your mods.
Deep pans..waste of $$ get a SD pan with the drain plug.
CT Performance, Inc. is offline
post #4 of 24 Old 06-28-2011, 10:20 AM
Derek@VisionDiesel's Avatar
Send a message via AIM to Derek@VisionDiesel Send a message via Yahoo to Derek@VisionDiesel
The trans command will eat your transmission, Ive been there and done that.
I switched from that module to a module PLUS a generic shift kit. Then i pulled the shift kit and the trans command and put in a BTS valve body, couldnt of been happier. Smooth crisp shifts as long as i wasnt trying to put 500hp to the wheels.
And well....
Now ive got a full BTS and havent stopped smiling yet
1996 f350- 615hp/1258tq uncorrected
2008 KR f350- leveled and tuned 569hp/1158tq
Cascade Coal Rollers!
Derek@VisionDiesel is offline
post #5 of 24 Old 06-28-2011, 10:22 AM
kylev90's Avatar
Quoted: 4 Post(s)
good info. I was under the impression the trans command was doing good. Glad I didnt buy one
kylev90 is offline
post #6 of 24 Old 06-29-2011, 08:41 AM Thread Starter
so would the bully dog one be a good choice?
s.hiles is offline
post #7 of 24 Old 06-29-2011, 08:44 AM Thread Starter
s.hiles is offline
post #8 of 24 Old 06-29-2011, 06:18 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
Had a Transgo "Tugger" kit in my last truck, was really happy with it.
Transgo Extreme Duty "Tugger" Shift Kit - Ford Truck E4OD and 4R100
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #9 of 24 Old 06-29-2011, 11:16 PM
So what's the diff in shifting between custom tunes like tw, a vb, and a shift kit?? I was under the impression that custom tunes would be plenty enough to make the autos shift good. So what's the dif between all 3 of those?
85_305 is offline
post #10 of 24 Old 06-30-2011, 02:55 AM
Hillbilly Deluxe
Quoted: 4 Post(s)
X2 on the deep pan, i got an SD pan with drain plug and i highly recommend!!!! I go mine for free...
TW is a chip that in installed in your PCM, increases HP and reprograms shift points in the PCM...
The "Valve Body" is located in the trans and is what controls the pressures in the trans through valves. This pressure is measured by the shift solenoids which send these pressure "signals" to the PCM which shifts the trans based on these inputs. There are 2 VB's in the E4OD.
A "shift kit" modifies the VB by changing pressures and allowing for longer smoother shifting. This can be a DIY mod, but i would give a 4 out of 5 wrenches on the difficulty scale. Most shift kits require drilling several holes in the primary and secondary VB's. Most trans shops can install these for you.
Seth
Stroked_NY_023
