What Brand of Glow Plugs are best for 7.3 Powerstroke? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-26-2011, 03:42 PM Thread Starter
Frostbite's Avatar
Quoted: 10 Post(s)
I am going to have my injectors upgraded to stage 1s. I plan to replace the glow plugs since I have the valve covers off. I have two questions really.
1. What brand of glow plugs work best in our trucks? I see there are a bunch of different brands of glow plugs out there. I am guessing Motorcraft but, I may be mistaken.
2. While I'm at it, should I change my valve cover gaskets or wiring harnesses for the injectors? My truck is a one owner (me) and has 80,000 miles.
Is there any other parts I should have on hand or replace while I have the injectors out?
2016 Ford F-350 4x4 6.7 Powerstroke, Lariat Ultimate Package.
I also still have my 97 Extended Cab 4x4 which I am the original owner of with 98,000 miles, Unlimited Diesel 175/30 Stage 1.5 Injectors, ATS Intercooler, Tony Wildman 6 Position Chip, 4" Turbo Back Diamond Eye Exhaust, Stealth SPR1 HPOP, Wicked Wheel 2, Hypermax Combo Boost/EGT Gauge, DIY Intake, FPR Mod, CCV Mod, IDM Mod, 203 degree T Stat, Stainless Steel High Pressure Crossover Line, Fitch Fuel Catalyst, 40,000 lb. Trucool Max Transmission Cooler. Next up a Bean's D-66, electric fuel, torque converter and a valve body.
Frostbite is offline
post #2 of 15 Old 05-26-2011, 03:44 PM
Quoted: 5 Post(s)
Beru / Motorcraft (OEM) are the best to use.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 15 Old 05-26-2011, 03:49 PM
superduty4x4's Avatar
They are the only ones that should be used
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #4 of 15 Old 05-26-2011, 04:03 PM
Quoted: 5 Post(s)
well......unless you dont mind seized plugs lol
ianstew is offline
post #5 of 15 Old 05-26-2011, 04:12 PM Thread Starter
Frostbite's Avatar
Quoted: 10 Post(s)
Thanks guys!
What about changing the other stuff I asked about?
post #6 of 15 Old 05-26-2011, 04:56 PM
Quoted: 5 Post(s)
the gaskets are reusable, but if you have any broken UVCH clips, or missing rubber boots on them, replace them while you are in there.
ianstew is offline
post #7 of 15 Old 05-26-2011, 07:53 PM Thread Starter
Frostbite's Avatar
Quoted: 10 Post(s)
Got it!
I guess when I take everthing apart I should be able to more easily tell what I need. I also need to send my chip to Tony to be reburnt for the stage 1 injectors and the Stealth SRP1
post #8 of 15 Old 05-26-2011, 08:20 PM Thread Starter
Frostbite's Avatar
Quoted: 10 Post(s)
Hum............ I saw these on Ebay. Is there any credibility to what they are saying here about glow plugs that heat up faster and are 100 degrees hotter? Take a look, what do you think?
Ford 7.3 Diesel Powerstroke Glowplugs Glow Plugs 95-03 | eBay
However, these are the ones I will probably order. Are these the right ones?
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
post #9 of 15 Old 05-26-2011, 09:15 PM
Quoted: 5 Post(s)
the second link is the ones to get
ianstew is offline
The Following User Says Thank You to ianstew For This Useful Post:
ptrent (06-02-2014)
post #10 of 15 Old 05-27-2011, 06:42 AM
Do not use aftermarket glow plugs. The tips can swell causing them to break off in the head when you try to remove them. Stick with the OEM stuff.
