Ambulance Alternator upgrade - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 44 Old 11-18-2010, 01:47 PM
BuickLeSabre1960's Avatar
Here's the type fuse I used on my amp and some bigger equipment I've worked on, the one here is a 200 amp but they've got to 300
Store Locator | NAPA Online
1997 F350 with a couple things done to it
If all else fails, immortality can always be assured by spectacular error
BuickLeSabre1960 is offline
post #12 of 44 Old 11-18-2010, 01:50 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
uh bad links?
EDIT: im to dumb to use the internet, im gonna sign off for a while...............
Trucks and parts............
kanuck15 is offline
post #13 of 44 Old 11-18-2010, 02:16 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
Thanks for that. Good info
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #14 of 44 Old 11-18-2010, 07:59 PM Thread Starter
Aaron Berk's Avatar
These are the type of fuses I like, I use em on my inverter setup ANL Fuse and Holder - DonRowe.com They are called ANL fuses.
The ones from Napa look to be the same but more industrial type housing, I like it.
I'm wondering how much of the Harness I'll be changing. I've already monkeyed with my battery set up. I have my dual batteries both on the passenger side. And I'm looking into stuffing an isolator over there too.
I've got a bunch of 6awg welding type cable, but I'm thinking I'd need to go bigger.
I'm still in La-La land with all this. Nothing major has been purchased yet.
There are pics of my battery set up in my Sig link if any one cares.
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #15 of 44 Old 11-25-2010, 07:10 AM
jeepbus's Avatar
Feedback Score: -1 reviews
Just a little advice.I am a Fleet manager for a large Ambulance fleet.We have several of those Alternators on our older units and yes you do get right at 200 amps out of them ,but they are the most unreliable things out there.I thought it was the vendor at firstbut it wasnt.I hope you guys get good service out of yours.As far as the wireing just upgrading the main charging cable to a good welding cable and you will be golden.
jeepbus is offline
post #16 of 44 Old 11-25-2010, 05:01 PM
Feedback Score: 3 reviews
I'm not trying to be a know it all but with two batteries at 850 amps each is 1700 and the alt power wire is tied right into the batteries would 215amps really kill that wire?
96F350KID is offline
post #17 of 44 Old 11-25-2010, 05:25 PM
Electrical Ogre
Quoted: 113 Post(s)
You're referring to the battery cables. The wire in question is the one from the alternator to the battery (starter solenoid)
Bill
2008 Ranger SC FX4
post #18 of 44 Old 11-25-2010, 11:59 PM
Yea thats the one i'm refering to its hot all the time with two 850 amp batteries flowing into it. I'm just asking if 215 amps is gonna kill that wire?
post #19 of 44 Old 11-26-2010, 05:36 PM
KB3MMX's Avatar
I just made a 6ga jumper wire from the alternator to the Glow plug solenoid battery side, the load can go to the batteries through that and the normal alternator wire now.
The 200amp alternator also needs some longer bolts, a slightly longer belt and some grinding to the inside webbing of the factory bracket.... and other than that, it plugs right in with the same alternator plug!
Definetely worth the easy upgrade !!
KB3MMX is offline
post #20 of 44 Old 11-26-2010, 06:29 PM
Originally Posted by kanuck15 View Post
I wondered about buying a ford harness, Cant be all that tough to build my own. think using a fuse like for an amplifier would work? they seem rather healthy
RJM Injection Tech Alternator Accessories & Parts
It's really for small block fords..but..
Need4racin is offline
